Topic: Simple counting/increment per iteration (Read 2275 times) previous topic - next topic
yost87
Ah!!! Rolling over... okay, I can account for that in the future.  It was not knowing why that was driving nuts (not the steering wheel in my lap).
Mucho grassyass! to all of you
Nick Gammon
Quote
Nick Gammon
Global Moderator
This will certainly fail:
Code:
int loops = 3;   //FAIL
while ( loops != 1 ){  //fAIL
Thanks for pointing that out, but why will it certainly fail?
I left out a line, sorry:
Code: [Select]
  // loops - 1;
First, you aren't subtracting one. Second, this is not how you subtract one:
Code: [Select]
loops - 1;
What was wrong with my suggestion?
Code: [Select]
for (int loops = 0; loops < 3; loops++)
  // do something
Instead of:
Code: [Select]
  static int loops = 6;   //FAIL - stops after the 3rd time
    if (loops > 0){  //fAIL
    loops =  loops - 1;
    for (int thisPin = 1; thisPin < pinCount; thisPin++) {
  // turn the pin on:
    digitalWrite(thisPin, HIGH);
    delay(timer);
  // turn the pin off:
    digitalWrite(thisPin, LOW);
Code: [Select]
  for (int loops = 0; loops < 6; loops ++)
      delay(timer);
      delay(timer);
      } // end of for each pin
    }  // end of for each loop
}  // end of loop
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
