Pages: [1] 2   Go Down
Author Topic: Simple counting/increment per iteration  (Read 268 times)
Hello, thanks for taking the time to even read my post with the expectation of offering help!
I am trying to simply light 10 LEDs in sequence from low to high, DONE
I am trying to simply light 10 LEDs in sequence from high to low, DONE
I am trying to change the timing/delay of each afore mentioned events, DONE
I am trying to make any part of this stop after n times (n is the number of times I will choose) FAIL
-also, how do I get more than one LED to light simultaneously?
So, I got the sequencing but cannot get a DO, WHILE, DO WHILE, or FOR to stop the looping, EVER.
I declared an integer [loops] and tried to increment/decrement using loops++, loops--, ++loops, --loops, loops +1, loops - 1, loops = loops -1, loops = loops +1, loops != 1, loops !0 (I read that when the WHILE becomes FALSE is when the event is recognized)
here is the last attempt with some of the bad code commented out
//int thisPin = 0;
int timer = 100;           // The higher the number, the slower the timing.
int pinCount = 10;        // using 10 LEDs
//  int loops = 3;          //FAIL
//  int thisPin;
  // use a for loop to initialize each pin as an output:
  for (int thisPin = 1; thisPin < pinCount; thisPin++)  {
    pinMode(thisPin, OUTPUT);
while ( loops != 1 ){  //fAIL
  // loops - 1;
  // turn the pin on:
    digitalWrite(thisPin, HIGH);
    delay(timer);
  // turn the pin off:
    digitalWrite(thisPin, LOW);
Melbourne, Australia
Shannon Member
Lua rocks!
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
Shannon Member
Lua rocks!
This will certainly fail:
What about:
for (int loops = 0; loops < 3; loops++)
  // do something
Netherlands
use CTRL-T in the IDE to auto layout the code
  int loops = 3;
    loops = loops - 1;
      delay(timer);
      delay(timer);
  while(1); // block forever
Rob Tillaart
Nick Gammon
Thanks for pointing that out, but why will it certainly fail?
robtillaart
Netherlands,
thank you!  i will compare what you did to what i have tried.
robtillaart
Netherlands
I tried what you did and that does not work for me either.  your code runs the method 1 time then stops, and I don't understand what you are trying to do with what you posted.
SO, I still do not have a way to stop the sequence after n times, any help????
Thanks all
California
Change the loops #.
« Last Edit: November 08, 2012, 04:25:32 pm by Arrch » Logged
Boston
See if this is easier to understand. Code is not tested.
int count = 0;
void setup(void) {
void loop(void) {
 count++;
 if (count <=8) // change 8 to number you want
 ledSequence();
void ledSequence()
  //do stuff here
Arrch
California
i tried to change the integer and that did not work either...
Try this:
  static int loops = 3;   //FAIL - stops after the 3rd time
  loops =  loops - 1;
  if ( loops){  //fAIL
  // turn the pin on:
    delay(timer);
Pauly,
Thanks but no go!  That did not work either.  How something so simple be so difficult???
Still n o solution...
int count = 0;
int timer = 100;
void setup(void) {
  for (int thisPin = 1; thisPin < 10; thisPin++)  {
void loop(void) {
 count++;
  //do stuff here
   for (int thisPin = 10; thisPin >= 1; thisPin--) {
  // turn the pin on:
    delay(timer);
Moving one line:
  if ( loops){  //fAIL
    loops =  loops - 1;
  // turn the pin on:
    delay(timer);
void loop(void) {
 count++;
What happens here is that as count gets incremented passing 8, the "if" section will not be executed. However, count will roll-over and the "if" section gets executed.
Instead, if you put the "count++" inside the "if", you will be fine.
dHenry, thanks!!!  I tweaked what you posted and got this which works...
Thanks all!
int pinCount = 10;
  static int loops = 6;   //FAIL - stops after the 3rd time
    if (loops > 0){  //fAIL
    loops =  loops - 1;
  // turn the pin on:
    delay(timer);
« Last Edit: November 08, 2012, 04:54:17 pm by yost87 » Logged
Pages: [1] 2   Go Up
