Topic: relay shield? (Read 572 times) previous topic - next topic
merlin2049er
Hi, what's the largest # of relay channels the arduino can handle?
What I'd like to do is use relays to control a stepped attenuator or TVC with a bluetooth module (and android using btinterfaces).
Thanks,
Joe
larryd
Each o/p can power a driver transistor or driver chip which in turn can drive a relay.
You can use multiple extender ICs, registers that can be placed in series to extend your relay count.
Why not tell us how many relays you need to drive?
No technical PMs.
The last thing you did is where you should start looking.
merlin2049er
23 steps x 2 channels.
I was thinking of removing the physical switches for relays, control via bt and arduino.
larryd
Which Arduino chip/board are you thinking of using?
No technical PMs.
larryd
Review this:
http://tronixstuff.wordpress.com/2011/08/26/tutorial-maximising-your-arduinos-io-ports/
No technical PMs.
