Topic: Long Range RFID Project (Read 44979 times) previous topic - next topic
gyepesto
Hi Guys,
I'm the new member of this forum and this hardware whose name is Arduino.
I want to make RFID project but it has to work in long range. It means that my RFID reader has to perceive the tag 3-4 meters away.
What components I have to buy? If you write them with prices, I'll be happy.
Thanks for your interest.
PaulS
Quote
An active RFID reader, with active RFiD (not passive) cards.
Quote
No, you won't. Active RFID systems are several orders of magnitude more expensive than passive RFID systems.
CrossRoads
Maybe you can make a potato chip can antenna work like they do on TV.
gyepesto
#3
Nov 09, 2012, 02:07 pm Last Edit: Nov 09, 2012, 02:09 pm by gyepesto Reason: 1
Hmm I have to buy active RFID reader, it's good. But I don't know how can I determine it works with Arduino or not.
For example this http://www.gaorfid.com/index.php?main_page=product_info&cPath=128&products_id=687 module's frequence is between 870-950 mhz but I don't know is it suitable for using with Arduino.
Can anyone choose the components which I have to use from this web site please?..
PeterH
Do you understand that you have to buy active tags?
gyepesto
Yes, there is no problem with them. My problem is about which devices is suitable for using with Arduino. I'm waiting answer to this question.
For example can you show one of suitable rfid reader and tag whose range between 3-4 meters.
CrossRoads
What have you found in your google searches so far?
Grumpy_Mike
Quote
You will have to say what device first before anyone can say if it will work with an Arduino.
There are many different types of reader.
Also 870-950 MHz is not the only frequency you can get active RFID tags, maybe some of the others might be cheaper.
gyepesto
For example this one. http://www.alibaba.com/product-gs/227232953/RFID_long_range_reader.html?s=p
It meets my needs. Can I use with Arduino Mega?
I want to buy Arduino Mega. Yes, 900mhz may be expensive but I said at start, I am newbie. :(
Grumpy_Mike
#9
Nov 09, 2012, 09:57 pm Last Edit: Nov 09, 2012, 09:58 pm by Grumpy_Mike Reason: 1
The link says:-
Quote
(3)RS232/TCP/IP ports
So yes using an RS232 to TTL converter it will work with an arduino.
It also says it has:-
Quote
3.Wiegand26/34
So that is another way to get an arduino to read it. That can be done with only two transistors to interface it.
gyepesto
It means that if there is a ttl, it can be used with Arduino. Am I right?
http://www.parallax.com/Store/Accessories/CommunicationRF/tabid/161/CategoryID/36/List/0/SortField/0/catpageindex/1/Level/a/ProductID/582/Default.aspx is suitable for my Arduino?
PaulS
Quote
Usually. Unless the current requirements are too high.
What does that have to do with RFID?
gyepesto
I just want to make car parking system. So it has to read the tag 3-4 meters away from barrier.
PaulS
Quote
I got that from the first post. What I don't get is what the 433 MHz RF Transceiver is going to be doing.
gyepesto
Someone said me; "RFID reader's mhz is must be high" so I'm searching them. Is there any problem? If you have any idea or advice I'll be happy.
