Topic: A story of three xbees; two emitters and one hub (Read 3178 times) previous topic - next topic
danieljay
So I have two transmitting xbees sending data to a central arduino/xbee and that part is dandy. (btw, im working in transparent mode).
Now since these are all talking on the same serial port, I am getting both values mushed together when I want to be able to distinguish between each value from each emitting xbee.
tips? suggestions? whats possible?
Jack Christensen
Have the transmitting XBees include a unique identifier with the data. Could just be a single character.
Or are you saying you are seeing the data from the two transmitting nodes interleaved at the receiver?
danieljay
#2
Nov 09, 2012, 05:46 am Last Edit: Nov 09, 2012, 05:48 am by danieljay Reason: 1
Quote
I've tried your suggestion before, but might not be executing it right. for one of the transmitters, I am serially writing the incoming sensor value and and 'A' to establish an identifier like so:
Code: [Select]
  Serial.write('A');
Serial.write(average);
delay(100);
am I completely off? what were you suggesting?
oh, and let me clarify, im sending sensor data from each transmitting xbee to a single receiving xbee. I am getting the sensor readings, except everything is all being mushed together when I am reading from the receiving end.
Jack Christensen
Yes, that is exactly what I was suggesting, but define "mushed". If one transmitter sends "A123" and the other sends "B999", is the receiver seeing something like "AB129399"?
danieljay
Quote
It fluctuates between the values. So in other words, when printing in the receiver, i.e. im just listening to any old thing coming into the serial port, i get a  flash of one value from one emitter then another value from the other. Make sense? I guess yes they are overlapping each other
Jack Christensen
But is any single message from either transmitter intact? "One value from one emitter then another value from the other" is what I might expect, best case.
Or are characters from one transmitter intermixed with those from the other transmitter?
danieljay
I want to dumb this down to be 100% sure I answer that correctly.
So I two dividing print lines in the receiver that show two different Serial.read() variables I created. When printed, I first place one xbee transmitter  20 feet away, then I have another within arms reach the incoming lines both sync to the same number until I shift around one of the transmitters, then that new incoming value shows up, and affects everything else.
Jack Christensen
How about posting the code for the receiver.
Also post a copy of the output, and explain how it is not what you expected.
My gut feel on this is that the data from the two transmitters stands to get mixed up, unless measures are taken to prevent it. The best approach might be to change to API mode. It can probably be made to work in transparent mode, but some scheme to prevent the two transmitters from transmitting simultaneously will be needed. Such an implementation stands to be relatively clunky as compared to API mode.
danieljay
Receiver Code :
Code: [Select]
#include <LiquidCrystal.h>
const int ledPin = 13;
//const int signalStrengthPin = 9;
//byte incomingByte, val_read;
int val_read;
int emitter2;
//int RSSIpin = 9;
//unsigned long rssiDur;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  Serial.begin(38400);
lcd.begin(16,2);
lcd.noAutoscroll();
  pinMode(ledPin, OUTPUT);
// pinMode(signalStrengthPin, INPUT);
//rssiDur = pulseIn(RSSIpin, LOW, 200);
  // print signal strength
  //Serial.println(rssiDur);
  if (Serial.available()>0)
   // if ((int(val_read) == 'B'))
val_read = Serial.read();
Serial.println(int(val_read));
delay(100);
//delay(100);
//Serial.print(int(inches));
lcd.setCursor(0,0);
lcd.print("Bike1 = ");
lcd.print(int(val_read), DEC);
  emitterTwo();
void emitterTwo(){
   if ((int(val_read) == 1))
      emitter2 = Serial.read();
      Serial.println(int(emitter2));
      delay(100);
      lcd.setCursor(0,1);
lcd.print("Bike2 = ");
lcd.print(int(emitter2), DEC);
...and Emitter Code for only of the modules (basically same exact code) :
Code: [Select]
//Transmitter modules. These are the bike units intended to show signal strength indication in correlation to a central networked hub.
//x bees have been configured with personal ID's to avoid interference with other networks (encryption).
//optimal xbee use is outdoors, no wall interference/metal(close contact). range is 300ft at optimal conditions.
const int rssi_pin = 9; //RSSI Pin of the XBee Module
int rssiDur; //variable to read pin
byte inches_val;
//LED pins//////////////////////////
const int led3 = 3;
const int led4 = 4;
const int led5 = 5;
const int led6 = 6;
const int led7= 7;
const int led8= 8;
const int led10= 10;
const int led11= 11;
const int led12= 12;
const int led13= 13;
///Averager Variables///////////////////////////////
//this is intended to place first 10 read incoming RSSI values in an array and average. smoother readings
const int numReadings = 10;
int readings[numReadings];      // the readings from the RSSI
int index = 0;                  // the index of the current reading
int total = 0;                  // the running total
int average = 0;                // the average
void setup(){
   for (int thisReading = 0; thisReading < numReadings; thisReading++)
    readings[thisReading] = 0;
pinMode (led3, OUTPUT);
pinMode (led4, OUTPUT);
pinMode (led5, OUTPUT);
pinMode (led6, OUTPUT);
pinMode (led7, OUTPUT);
pinMode (led8, OUTPUT);
pinMode (led10, OUTPUT);
pinMode (led11, OUTPUT);
pinMode (led12, OUTPUT);
pinMode (led13, OUTPUT);
   //Serial1.begin(38400);
  Serial.begin(38400); //Xbee communicating at this baud
void loop(){
rssiDur = pulseIn(rssi_pin, LOW, 200); //this is set to 200ms with ATRP @ 2
inches_val = rssiDur; // XBee times out 10-12 inches apart, so added 11
inches_val = rssiDur + 24; // XBee times out 10-12 inches apart, so added 11
min(inches_val, 1);
//min(inches_val, 18);
total= total - readings[index];
  // read from the sensor:
  readings[index] = inches_val;
  // add the reading to the total:
  total= total + readings[index];
  // advance to the next position in the array:
  index = index + 1;
  // if we're at the end of the array...
  if (index >= numReadings)
    // ...wrap around to the beginning:
    index = 0;
  // calculate the average:
  average = total / numReadings;
//Serial.print("Signal Strength distance inches = ");
//Serial.println(average );
  Serial.write(1);
    //Serial.write("emitter two");
  delay(100);        // delay in between rea
// value 10 = 1 meter
if (average > 24 && average < 124){ //1-5 meters
// Serial.write(1);
   digitalWrite(led3, HIGH);
       digitalWrite(led4, HIGH);
        digitalWrite(led5, HIGH);
        digitalWrite(led6, HIGH);
        digitalWrite(led7, HIGH);
        digitalWrite(led8, HIGH);
        digitalWrite(led10, HIGH);
        digitalWrite(led11, HIGH);
        digitalWrite(led12, HIGH);
        digitalWrite(led13, HIGH);
  if (average > 124 && average < 224){ //5-10 meters
  //Serial.write(2);
        digitalWrite(led12, LOW);
        digitalWrite(led13, LOW);
  if (average > 224 && average < 324){ //10- 15 meters
  //Serial.write(3); //this is 10 meters. write to reciever
         digitalWrite(led10, LOW);
        digitalWrite(led11, LOW);
  if (average > 324 && average < 424){ //15-20 meters
  //Serial.write(4);
        digitalWrite(led7, LOW);
           digitalWrite(led8, LOW);
  if (average > 424 ){ //20-30 meters
// Serial.write(5);
        digitalWrite(led5, LOW);
        digitalWrite(led6, LOW);
    //isolated instances below
  if (average == 24 ){ //if their is no signal
  Serial.write(9);
   digitalWrite(led3, LOW);
       digitalWrite(led4, LOW);
both emitter values show up, but overlapping each other. and not mixed together, I mean with this code It shows one value, clears, then shows another value from other emitter, but all in same line.
And Im sure API mode would be useful, but I am not too comfortable right now to take on a new beast. If it is a must, and their isn't a good suggestion for what I am doing now, I need a push in the right direction for API mode aside from configuring AT command and installing an arduino library.
Jack Christensen
OK I'll have a look. What kind of XBees are these? Series 1? Series 2?
Jack Christensen
#10
Nov 09, 2012, 06:08 pm Last Edit: Nov 09, 2012, 06:10 pm by Jack Christensen Reason: 1
Here are a few things off the top.
1. delay(100) in receiver code. Since there are two transmitters each sending every 100ms, probably the code never gets to the emitterTwo() function. I would use no delay in the receiver. It should constantly be watching for incoming data, not "sleeping" -- it can do nothing while delay() executes.
2. int(val_read) does nothing, since val_read is an int.
3. Serial.read() reads a byte. Serial.write() writes a byte. So Serial.write(average), where average is an int, may not have the desired effect.
4. In emitterTwo(), the receiver code appears to check the first byte to identify the sender. But this is not done in loop(). The code should be consistent, should treat every incoming message identically, and there should be a fixed message structure. The code should not make assumptions about which transmitter's message might be received first, or that the two will always alternate perfectly. Some sort of message start delimiter may be a good thing. Just as a starting idea, each transmitter could always send a message like "*ndd" where the * is the start delimiter, n is a single byte identifying the transmitter, and dd is two bytes representing the data sent by the transmitter. Then the receiver code could watch for "*" as the start of a message, then decode the next three bytes accordingly. If another * shows up in the next three bytes, then that is an error, but would allow the receiver to re-sync.
5. It appears you are trying to determine distance (in inches!) based on the RSSI value. This will be a gross approximation at best. Further, if these are S2 (mesh) XBees, RSSI only represents the last hop, so it's entirely possible that the furthest transmitter would route through the closer one, and the hub would see no difference in the RSSI values for the two transmitters.
Hope this helps.
danieljay
danieljay
And can you give me a example in code ? Having hard time understanding that with syntax
Jack Christensen
#13
Nov 09, 2012, 06:19 pm Last Edit: Nov 09, 2012, 06:42 pm by Jack Christensen Reason: 1
An example of what exactly?
Transmitter code might look like
Code: [Select]
   const byte nodeID = 1;
   int myData;
   Serial.write('*');            //message start delimiter
   Serial.write(nodeID);
   Serial.write(myData >> 8);    //most significant byte
   Serial.write(myData & 0xFF);  //least significant byte
Receiver code might look like
Code: [Select]
   byte c;
   byte nodeID;
   int myData;
   c = Serial.read();
   if (c == '*') {                     //wait for start delimiter
       nodeID = Serial.read();
       myData = Serial.read() << 8;    //msb
       myData += Serial.read();        //lsb
       //message received and decoded, continue processing it...
Checking for a premature start delimiter is left as an exercise for the reader :D
danieljay
Great! When I get home I'm going to test this out and let you know. And start delimiter ? You mean some kinda delay for emitters? Unclear what you mean by that
