Topic: Calculate the minimum angular movement between two compass points? (Read 595 times) previous topic - next topic
warren631
Does anyone have a handy dandy function to do this (returns results from -180 to +180)?
For example:
move from 90 to 180 = 90 (easy)
move from 180 to 90 = -90 (easy)
move from 45 to 359 = -46 (not so easy)
move from 315 to 90 = 135 (not so easy)
(Clockwise move is positive, anti-clock is negative).
WizenedEE
function:
int angDist(int p1, int p2) {
  int rawdist = p2 - p1;
  while (rawdist <  -180) rawdist += 360;
  while (rawdist >= +180) rawdist -= 360;
  return rawdist;
and test code:
#include <iostream>
using namespace std;
  return rawdist;
#define printfunc(x,y) cout << "x: " << x << "y: " << y << "angDist(x, y): " << angDist(x, y) << endl
int main() {
    printfunc(90, 180);
    printfunc(180, 90);
    printfunc(45, 359);
    printfunc(315,90);
prints out results you gave
warren631
Thanks WizenedEE.  I also found these on the internet which might be of use to others looking for such a function:
int angle_difference(int target, int head){
  return ((((target - head) % 360) + 540) % 360) - 180;
int angleDifference(int target, int head){
  return abs((target + 180 -  head) % 360 - 180);
