Loading...
Pages: [1]   Go Down
Author Topic: HDSP 2111 problem  (Read 433 times)
Offline Offline
Newbie
View Profile
Hello,
This is is my first post here, and I thought I'd drop in with a nice problem(well not really).
Let me start by saying that im quite sure it must be something I am doing wrong. So if someone can poke a hole in what I've made then that be great.
What I am trying to do is hook up a couple of HDSP 2111 display to the arduino, with the intent to use this as a NAV/AP display(Nav1, Nav2, HDG/CRS, ALT, VS) for Flightsimulator(X, 2004).
I followed the NYC resistor tutorial and the Jos van Dijk tutorial:
http://www.nycresistor.com/2010/05/30/working-with-the-hdsp-2111/
http://www.josvandijken.nl/elektronica_HP_HDSP-2111.php
From this onward I added a HCT595N serial-in parallel-out shiftregister.
So far so good. Then I tried hooking up a serial connection via python(with pyserial and fsuipc, python extension from the SDK). This started given trouble(filled up block chars in the display).
So, to confirm the output was OK I hooked up the shiftregister to a bank of 8 LED's. As it turned out all the LED lit up as soon as I tried to display any of the serial data. Then I tried to show just a single character(pre defined) if any came in on the serial connection. The Arduino LED showed inbound activity but alas, again all the LED's burned bright.
So, just to make sure I wasnt crazy(heh..) I decided to do a simple loop to 255 and shift that out to the LED's. This worked fine, as long as I DONT do it in the loop() function(it works in setup(), or start() etc.).
I was a bit stumped since it didnt make any sense, to confirm it wasnt something in the code I copied it into its own script and compiled/uploaded that one. This didnt solve the problem. So right now im a bit stuck. I am sure it must be something that I am doing since the original example(josvandijk link) that I used worked perfectly(scrolling text). Right now I can only show a frequency or a heading in the setup() code. Any update during the loop() will either blank the display or show random characters.
This is the code I am using to control the display:
Code:
         Demo Code for HDSP-2111
 Jos van Dijken
 www.josvandijken.nl
 28 april 2012
 Based on the code from:
 Matt Joyce < matt at nycresistor.com >
 Mark Tabry
int RST   = A0;
int WR    = A1;
int CE    = 10;
int RD    = 11;
int AD0   = A2;
int AD1   = A3;
int AD2   = A4;
int AD3   = A5;
int DS    = 0; //shiftregister datapin
int ST_CP = 1; //shiftregister storageclock(latch)
int SH_CP = 2; //shiftregister shiftclock(data polling)
  pinMode(RST    , OUTPUT); //reset pin, init on startup
  pinMode(WR     , OUTPUT);
  pinMode(CE     , OUTPUT);
  pinMode(RD     , OUTPUT);
  pinMode(AD0    , OUTPUT); // data register selection // these 4 pins allow one to select a data register.
  pinMode(AD1    , OUTPUT); // data register selection
  pinMode(AD2    , OUTPUT); // data register selection
  pinMode(AD3    , OUTPUT); // data register selection
  pinMode(DS, OUTPUT); //shift register serial in
  pinMode(ST_CP, OUTPUT); //shift register storage pin(latch)
  pinMode(SH_CP, OUTPUT); //shift register clock pin(clock)
  digitalWrite(CE, HIGH); // chip enable, go low before wr. go high after wr
  digitalWrite(WR, HIGH); // write enable, go low to start write, go high when done.
  resetDisplay();
  start();
void resetDisplay()
  digitalWrite(RST, LOW);
  delayMicroseconds(1);
  digitalWrite(RST,HIGH);
  delayMicroseconds(150);
  digitalWrite(AD3, HIGH);
void writeDisplay(char *input)
  for (int i=0; i<8; i++)
    // below bit(AD0,1,2) is setting the correct display character index(i)
    digitalWrite(AD0, (1&i)!=0?HIGH:LOW); // bitwise AND[&] comparator(meaning both bits of 1 and i needs to be 1 to give true(set bit in result as 1).
    digitalWrite(AD1, (2&i)!=0?HIGH:LOW);
    digitalWrite(AD2, (4&i)!=0?HIGH:LOW);
    delay(1);
    digitalWrite(CE, LOW);
    delay(1);
    digitalWrite(WR, LOW);
    delay(1);
    digitalWrite(ST_CP, LOW);
    delay(1); //allow the display to retrieve the values set to the D pins(PORTD)
    shiftOut(DS, SH_CP, MSBFIRST, input[i]);
    delay(1);
    digitalWrite(ST_CP, HIGH);
    delay(1);
    delay(1);
    delay(100);
void start()
  char intro[] = "360  310";
  writeDisplay(intro);
  delay(100);
  for(int i = 0; i < 256; i++)
    Serial.print(i);
    shiftOut(DS, SH_CP, MSBFIRST, i);
    delay(1);
    delay(100);
And this is the code I am using for the test(copy'ed from other file).
Code:
  start();
void start()
    Serial.print(i);
    delay(1);
    delay(100);
This is the schematic created in eagle:
And a photo of the current setup. The only thing changed are that the wite and orange wires now lead to the red LED's.
I have been trying to figure out what is wrong for the last 2 days, and im quite sure im missing something.
I hope the image size doesnt exceed a limit, I tried looking up the rules for that. Alas. If it is a problem I will fix it, got to go in a few minutes though.
I am using a Arduino Duemilanove.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
The Serial interface is hardwired to use pins 0 and 1 - but these are also connected to your shift register - thus it will do strange things if using the USB/serial interface which also talks to pins 0 and 1.
Logged
Offline Offline
Newbie
View Profile
Thanks! That sounds remarkably simple to fix.
I actually read about the pins and noted the TX and RX signs next to them but discarded it since I figured setting them up as digital outputs would overwrite those properties. I shall try this later today!
Logged
Offline Offline
Newbie
View Profile
I tested it today and you are correct, it now works perfectly!
So, if port 0 to 7 can be set to digital output pins with PORTD would the same effect happend? Or is it some sort of lower level command that overrides the TX/RX function on those ports?
Logged
Pages: [1]   Go Up
Print
Jump to:
