Loading...
Pages: [1]   Go Down
Author Topic: debugging a serial communication tool  (Read 575 times)
Offline Offline
Newbie
View Profile
hey guys, i need some help debugging this code:
Code:
int open_portandprint(char* load){
int fd; /* File descriptor for the port */
fd = open("/dev/ttyACM0", O_RDWR | O_NDELAY);
    fcntl(fd, F_SETFL, 0);
struct termios options,oldtios;
if (tcgetattr(fd, &oldtios) != 0) return(-1);
cfsetispeed(&options, B9600);            /* setze 9600 bps */
cfsetospeed(&options, B9600);
options.c_cflag &= ~PARENB;               /*  kein Paritybit */
options.c_cflag &= ~CSTOPB;               /* 1 Stopbit */
  options.c_cflag &= ~CSIZE;                /* 8 Datenbits */
  options.c_cflag |= CS8;
options.c_oflag &= ~OPOST;
tcsetattr(fd, TCSANOW, &options);
int n = 0;
int m = strlen(load);
n =  write(fd, load, m);
return (fd);
it should initialize the virtual com port on my computer and write some bytes of code. but in only works, while i have telnet up an running. so i think some of my flags are wrong.
can somebody see what my problem is?
thank so far,
erik
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
This does not look like arduino code ...
what I see is that the fd is nowhere closed
what is n after the statement, it should be equal to m ...
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Newbie
View Profile
it is code that runs on my netbook.
ive done some experimenting and it seems, that when i run the code with the arduino connectet, the arduino reboots. on the arduino runs the SerialDisplay example, wich puts everything from the serial input off the arduino to a lcd (and this works, ive testet it with the serial monitor).
this code works, as long as i have the serial monitor open.
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
opening a serial port does set some HW handshake lines high/low.
I don't recall the details but they are discussed more on this forum -> search in the upper right for 'serial open reset Arduino' or so)
Logged
Rob Tillaart
Pages: [1]   Go Up
Print
Jump to:
