Topic: Can I build a project using 4 AA batteries with a 5V Arduino board? (Read 6429 times) previous topic - next topic
CrossRoads
I have  not done any testing Lefty. I don't have any of the new boards with the later regulator to try this with.
I do see that some of the arduino pages have this added now "Supplying voltage via the 5V or 3.3V pins bypasses the regulator, and can damage your board. We don't advise it. "
I was thinking perhaps connected but unpowered walwarts while powered from USB could be the culprit, but the reverse polarity protection diode should provide Vin isolation in that case.
retrolefty
Me neither.
Yes, I've seen that. I guess my question would be did they add that because of the recent change of voltage regulator or just because it's not a good engineering practice in general as I talked about below? Does anyone have a contact with a Arduino designer we could ask to find out their reason for posting that 'new' caution/recommendation?
Yes, the Vin isolation diode would prevent any current flow from the board to anything connected to the external power connector, powered or off.
Lefty
CrossRoads
Quote
PS:  And yes, like you my favourite way to power a standard arduino board with an external regulated +5vdc source is to take a spare USB cable, lop off the PC end and extract the power and ground wires and wire that to the external 5 vdc power supply.
I'd certainluy go along with that as a recommendation. The few times I use an actual arduino (as I usually have my own design going) I am powered via PC/USB cable for software download/test.
In my designs, I bring in 5V from a walwart to power the card. Or 12V if  LED strings are being powered, and use a 7805 regulator.
Or I bring in power via FTDI Basic for bootloading via MKii.
CrossRoads
Quote
I believe they did respond here a while ago, when the issue of bricked Mega's started coming up.
retrolefty
Quote
Did they state a reason?
Lefty
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
