Loading...
Pages: [1]   Go Down
Author Topic: A couple of questions about sound activation Lights  (Read 654 times)
Offline Offline
Newbie
View Profile
Hi,  I've been searching for LED and sound activated lighting and I came across the EL Wire technology and the Arduino microcontroller.
Since I have no knowledge on electronics (but a great will to start playing with it) I want to know if its possible and the gear/programming I need to:
1 - Have like 3 colors of lights and each one is activated by a range of sound frequency, lets say:
a --- Red for kicks/basslines;
b --- Yellow for claps/snares;
c --- Green for Hihats
(the colors and quantity are just examples)
So basically it would work kind of like an equalizer;
2 - Have one color for each instrument in a band; instead of having a set of colored lights reacting to the global sound of the band, each instrument would have a sound activated light that would respond to the intensity. (i guess I had to bypass each mic before it goes into the mixer so each one is activated individually and still can mix the sounds on the mixer);
3 - Having a set of lights respond to one single instrument and each color would correspond to a range of notes
(from my knowledge of music, each color would represent a range of sound frequency);
4 - Have a light blinking in sync with a " dubstep wobble bass" (i have this doubt just because it isn't the volume, its a frequency/LFO effect).
I hope I didn't made it hard to understand.
Therefore, like i said previously, I want to know if each topic is possible and the necessary gear and also if i can combine some (like 2 with 3 and 1 with 4).
Lights can be El Wire or LEDs, I suppose i can use one or another jsut by making slight adjustments to the circuit/layout.
Logged
USA, FL
Offline Offline
God Member
A life? Where can I download one of those?
View Profile
Since no one has chimed in, take a look at the LM3914.  It can light LEDs at different frequencies.  Also you can daisy chain them to get a higher range of frequencies.
But basically, yes, you can do all those things with an Arduino.  Google "Arduino lm3914" or the like and read up on them.  The LM39xx series chips are excellent.  I have the LM3914, LM3915, and LM3916 on hand just because they are simple and easy to use with an Arduino.
LM3914 Datasheet
Logged
//LiNK
Montreal
Offline Offline
Edison Member
Per aspera ad astra.
View Profile
WWW
Check on this blog:
http://coolarduino.wordpress.com/2012/06/21/tears-of-rainbow/
Logged
Offline Offline
God Member
View Profile
Quote
No!  The LM3914 is a bar/dot meter.   It "measures" volume, not frequency.   You could build 3 (or more) frequency-filters and use one LM3914 for each frequency band.  (That would work without a microcontroller.)
Quote
That's sort-of possible.  Except, hats, snares, and hand claps have very similar spectrums  You will not be able to isolate them (if they are mixed).
There is a handy chip called the MESGEQ7] that gives gives you the levels in 7 different bands.
Quote
2 - Have one color for each instrument in a band...
... i guess I had to bypass each mic before it goes into the mixer so each one is activated individually and still can mix the sounds on the mixer);
Right.  You'd have to split the mixer inputs and run them into the lighting system as well as the mixer.  And you'd probably need a preamp for each signal, although with a mic directly in front of a kick drum or guitar amp may have enough signal to work without a preamp.  Or, if your mixer has "sends" for each input,  you can use the mixer's preamps.   The Arduino Uno has 6 analog inputs.   The Mega has 16 analog inputs.
Quote
3 - Having a set of lights respond to one single instrument and each color would correspond to a range of notes...
Yes.  With hardware filters (made with op-amps) or the MSGEQ7, you can split the audio signal into frequency bands and run each band into an analog input.
Quote
Again, if the music is mixed you can isolate the bass frequencies, but not the instruments.  The bass signal will contain the kick drum and any other bass "notes".
Quote
Sure, you can have multiple effects.  Just count your inputs & outputs to make sure you have enough  (You can use serial shift-registers or matrixing to expand the number of outputs).  Just start-out simple and get something working before you try to get too fancy. smiley-wink
Quote
You'll need to check the voltage & current requrements.  You may need a MOSFET or something to boost the power.  (Same thing if you connect multiple LEDs to one output.)
Logged
Pages: [1]   Go Up
Print
Jump to:
