Topic: Time logging function and problem with temperature? (Read 960 times) previous topic - next topic
limjix
Hi everyone,
I am currently working on one of the ARDX projects about temperature.
Basically, it is logging temperature from a TMP36 IC
Here is the code
*     |  Arduino Experimentation Kit Example Code             |
*     |  CIRC-10 .: Temperature :. (TMP36 Temperature Sensor) |
*  A simple program to output the current temperature to the IDE's debug window
*  For more details on this circuit: http://tinyurl.com/c89tvd
//TMP36 Pin Variables
int temperaturePin = 0; //the analog pin the TMP36's Vout (sense) pin is connected to
                        //the resolution is 10 mV / degree centigrade
                        //(500 mV offset) to make negative temperatures an option
* setup() - this function runs once when you turn your Arduino on
* We initialize the serial connection with the computer
  Serial.begin(9600);  //Start the serial connection with the copmuter
                       //to view the result open the serial monitor
                       //last button beneath the file bar (looks like a box with an antenae)
void loop()                     // run over and over again
float temperature = getVoltage(temperaturePin);  //getting the voltage reading from the temperature sensor
temperature = (temperature - .5) * 100;          //converting from 10 mv per degree wit 500 mV offset
                                                  //to degrees ((volatge - 500mV) times 100)
Serial.println(temperature);                     //printing the result
delay(1000);                                     //waiting a second
* getVoltage() - returns the voltage on the analog input defined by
* pin
float getVoltage(int pin){
return (analogRead(pin) * .004882814); //converting from a 0 to 1023 digital range
                                        // to 0 to 5 volts (each 1 reading equals ~ 5 millivolts
I have 2 questions:
1. I replaced the TMP36 with LM35 because I don't have a TMP36. My readings are in negative values. Is there any reason why it should be?
I edited the code "temperature = (temperature - .5) * 100;" instead of .5 I changed it to 0.05 and it seems to give the right values. However I would like to confirm if I did it right?
2. I am wanting to add a time keeping function just like commercial dataloggers. Meaning, serial will print the temperature and the time since the start of the experiment. How should I code it in?
Thanks guys!
michael_x
1. I'm too lazy to search for datasheets to compare LM35 to TMP36 sensors
So read datasheets and check the maths. Do a calibration test with known temperatures over the whole range.
2.
Add a time keeping function just like commercial dataloggers. Meaning, serial will print the temperature and the time since the start of the experiment.
"commercial dataloggers" would apply RealTime timestamps, which is not available in a standard Arduino.
The "time since start of the experiment" is easier: take millis() and divide by 1000.
Spoonfeeding:  Add
Serial.print ( millis() / 1000); Serial.print (" s : ");
bfore your line
Getting hours/minutes/seconds from the number of seconds is beyond spoonfeeding.
If you're interested in that, give it a try yourself and only ask for help when really stuck.
PaulS
If you want to log clock time, you need a clock. The Arduino doesn't have one. It only has a stopwatch with a stop button that doesn't work. RTC (real time clock) chips are cheap and easy to use.
tuxduino
I had the same requirement on an Arduino project last year. I boutght an i2c rtc with integrated li-ion battery. On the Arduino, I used the Time library, which can use as a time source either the millis() function or an external i2c clock. Very convenient and easy to use. Quite heavy, but with lots of features to for time intervals manipulation.
robtillaart
check this site - http://www.ladyada.net/make/logshield/ -
Rob Tillaart
MikMo
If your Arduino is connected to your PC while logging you can use GoBetwino to do the logging, including a timestamp.
