Loading...
Pages: [1]   Go Down
Author Topic: Simple histogram class  (Read 636 times)
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Just added the  0.1 version of a histogram library to the playground. See - http://arduino.cc/playground/Main/Histogram -
The class uses an external array of floats to define the number of buckets and in which bucket new (measurement) data is to be added.
This example code shows the basic working of the buckets, note that the intervals are different in size.
Code:
//    FILE: hist_test.pde
//  AUTHOR: Rob Tillaart
//    DATE: 2012-11-10
// PUPROSE: test histogram library
#include "histogram.h"
float b[] = { 0, 300, 325, 350, 375, 400, 1000 };
Histogram hist(7, b);
unsigned long lastTime = 0;
const unsigned long threshold = 50;  // milliseconds, for updating display
  Serial.print("\nHistogram version: ");
  Serial.println(HISTOGRAM_LIB_VERSION);
  int x = analogRead(A0);
  hist.add(x);
  // update output
  unsigned long now = millis();
  if (now - lastTime > threshold)
    lastTime = now;
    Serial.print(hist.count());
    Serial.print("\t");
    for (int i = 0; i < hist.size(); i++)
      Serial.print((1.0*hist.bucket(i))/hist.count(),2);  // gives percentage per bucket
      Serial.print("\t");
    if (hist.count() > 100000UL) hist.clear();
As always all comments are welcome,
Rob
« Last Edit: November 10, 2012, 09:52:19 am by robtillaart » Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
I'd prefer to see the example not use delay().
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
OK, fair enough
 I'll fix it smiley
update -> done (playground too)
« Last Edit: November 10, 2012, 09:53:48 am by robtillaart » Logged
Rob Tillaart
Netherlands
Offline Offline
Tesla Member
View Profile
updated the histogram lib to 0.1.2 on the playground.
There are three experimental functions: PMF, CDF and VAL.
PMF is quite similar to frequency, but uses a value as parameter. (no knowledge of buckets is needed)
CDF gives the sum of frequencies <= value.
VAL is CDF inverted.
As the Arduino typical uses a small number of buckets (<20)  these functions are quite coarse or even inaccurate (read useless).
Linear interpolation within the buckets will improve the accuracy but it is unknown to what extend. If the average value of every bucket is available the interpolation can be better than just linear interpolation. However this additional code and storage will increase the footprint and complexity of the lib..
To be continued,
Logged
Rob Tillaart
Pages: [1]   Go Up
Print
Jump to:
