Topic: Thermal-IR Camera (video) (Read 2207 times) previous topic - next topic
ovcrash
I have in project to build a thermal-IR camera. I know there's already a arduino project to build something like this. What i want is something more in the range of a video camera with thermal-IR, not something that has to scan a area to make a thermal image. I want to it be live. I want to use this to go into the woods and see wildlife.
I was think of using the MLX90620 sensor. I don't know if this is possible. Any input from you guys would be appreciated.
Thanks alot.
AWOL
You're going to have to build some kind of scanning mechanism. (TICM is a useful search term)
How are your precision mechanics skills?
Grumpy_Mike
It is not just a matter of wiring up the sensor to get a 16 by 4 pixel image. You have to focus an image onto the sensor. For that you need a lens that works at far IR. That means a germanium or silicon lens and that means big $.
A lot of money for a very small image.
ovcrash
So building something in the line of this: http://www.flir.com/cs/apac/en/view/?id=54138 is pretty much impossible?
AWOL
That device is almost certainly a staring array, not mechanically scanned.
It clearly isn't impossible though, because you can buy one.
It is probably also near-IR.
ovcrash
Thanks for your inputs. I know i could buy one, but i'm going to have more fun building one.
AWOL
As Mike said, the optics are exotic (most common glass is opaque/reflective to the sorts of wavelengths you're interested in - find some thermal footage on YouTube and try looking into cars) and a 16 x 4 image by itself is very limited, so the scanning mechanism is essential.
Grumpy_Mike
It says:-
Employing either a 320 × 240 or 640 × 480 FLIR thermal imaging core with advanced image-processing algorithms,
So an arduino with a 320 X 240 image will need 76.8K bytes, how is this going to fit into the 2K SDRM?
So building something like that with an arduino is impossible.
AWOL
I was assuming that you'd be reading and sending a row (or even a pixel) at a time, not as an entire image.
However, there remains the problem of digitising at video rates.
This really ins't Arduino territory, unless you're only using it to drive the scanning mechanism.
sbright33
I bought an excellent IR hunters camera that only takes 2ma while sensing, and costs $100.
You can't build that for less!
