Loading...
Pages: [1]   Go Down
Author Topic: Arduino Powered Chess Playing Robot  (Read 514 times)
Offline Offline
Newbie
View Profile
Wonder if anybody here could help me figure out how the wiring of this project has been done. I guess if I got atleast a schematic diagram for this project, I can be able to make this project work (I wish smiley-small) . I got a resource from the internet but I'm a newbie and I still got to learn more. It would be a good start if you could help me out. I'm trying to make a chess playing robot. For the chess sensory board, I need 64 reed switches for each squares of the board. The opponent will be the robot itself and it will move the pieces using motors. I'm having a hard time in how can I be able to connect everything. I guess it would be better posting the link for further understanding. http://www.instructables.com/id/How-to-Build-an-Arduino-Powered-Chess-Playing-Robo/?ALLSTEPS
this is the program for the chess  sensory board
Code:
#include <SoftwareSerial.h>
//Give convenient names to the control pins
#define CONTROL0 5
#define CONTROL1 4
#define CONTROL2 3
#define CONTROL3 2
#define rxPin 10
#define txPin 11
//Create arrays for data from the the MUXs
//See the Arduino Array Reference: http://www.arduino.cc/en/Reference/Array
int mux0array[16];
int mux1array[16];
int mux2array[16];
int digitalpins[16];
int mux0arraycheck[16];
int mux1arraycheck[16];
int mux2arraycheck[16];
int digitalpinscheck[16];
int descrepicount = 0;
char * squares[] = {"A1","A2","A3","A4","A5","A6","A7","A8","B1","B2","B3","B4","B5","B6","B7","B8","C1","C2","C3","C4","C5","C6","C7","C8","D1","D2","D3","D4","D5","D6","D7","D8","E1","E2","E3","E4","E5","E6","E7","E8","F1","F2","F3","F4","F5","F6","F7","F8","G1","G2","G3","G4","G5","G6","G7","G8","H1","H2","H3","H4","H5","H6","H7","H8"};
int lastprinted;
SoftwareSerial mySerial = SoftwareSerial(rxPin, txPin);
//Set MUX control pins to output
pinMode(CONTROL0, OUTPUT);
pinMode(CONTROL1, OUTPUT);
pinMode(CONTROL2, OUTPUT);
pinMode(CONTROL3, OUTPUT);
for(int i=23; i < 39; i++){
pinMode(i, INPUT);
//Open the serial port at 9600 bps
Serial.println("Startup");
//Set analog pins to digital input
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode(A2, INPUT);
//Turn on pullup resistors
digitalWrite(A0, HIGH);
digitalWrite(A1, HIGH);
digitalWrite(A2, HIGH);
pinMode(rxPin, INPUT);
pinMode(txPin, OUTPUT);
/*for(int i = 0; i < 16; i++){
digitalpins[i] = 1;
digitalpinscheck[i] = 1;
for (int i=0; i<16; i++)
//The following 4 commands set the correct logic for the control pins to select the desired input
//See the Arduino Bitwise AND Reference: http://www.arduino.cc/en/Reference/BitwiseAnd
//See the Aruino Bitshift Reference: http://www.arduino.cc/en/Reference/Bitshift
digitalWrite(CONTROL0, (i&15)>>3);
digitalWrite(CONTROL1, (i&7)>>2);
digitalWrite(CONTROL2, (i&3)>>1);
digitalWrite(CONTROL3, (i&1));
//Read and store the input
//Since internal pullup is on, the pin goes low on changing, so the value needs to be flipped from 0 to 1 (!)
mux0array[i] = !digitalRead(A0);
//This for loop is used to scroll through the SECOND multiplexer
mux1array[i] = !digitalRead(A1);
//This for loop is used to scroll through the THIRD multiplexer
mux2array[i] = !digitalRead(A2);
for (int b = 0; b < 16; b++){
digitalpins[b] = digitalRead(b + 23);
//delay(1000); //Wait for the computer to move so we don't detect any false input from the other magnets
//it adds 12 seconds to startup time but that doesn't really matter... we're setting the board up anyway :)
//sets the array to digitalreads of built in mega pins 23 - 39
//This for loop is used to scroll through and store the 16 inputs on the FIRST multiplexer
////////////Check if anything has changed...
if(digitalpinscheck[b] != digitalpins[b]){
if(lastprinted != b || descrepicount == 0){
Serial.print((squares[b]));
lastprinted = b;
descrepicount = descrepicount + 1;
if(descrepicount >= 2){
descrepicount = 0;
if(mux0arraycheck[b] != mux0array[b]){
Serial.print((squares[b + 16]));
lastprinted = b;
descrepicount = 0;
if(mux1arraycheck[b] != mux1array[b]){
Serial.print((squares[b + 32]));
lastprinted = b;
descrepicount = 0;
if(mux2arraycheck[b] != mux2array[b]){
Serial.print((squares[b + 48]));
lastprinted = b;
descrepicount = 0;
digitalpinscheck[b] = digitalpins[b];
mux2arraycheck[b] = mux2array[b];
mux1arraycheck[b] = mux1array[b];
mux0arraycheck[b] = mux0array[b];
//DEBUG
//The following lines are for printing out results of the internal pins
Serial.print("internal pins: ");
Serial.print(digitalpins[i]);
Serial.print(",");
Serial.println(); //line feed
//The following lines are for printing out results of array0
Serial.print("mux0array: ");
Serial.print(mux0array[i]);
Serial.print(",");
Serial.print(",");
//The following lines are for printing out results of array1
Serial.print("mux1array: ");
Serial.print(mux1array[i]);
Serial.print(",");
Serial.print(",");
//The following lines are for printing out results of array2
Serial.print("mux2array: ");
Serial.print(mux2array[i]);
Serial.print(",");
Serial.print(",");
Please chip in. Any help would be highly appreciated. Thank you. God Speed. smiley
« Last Edit: November 10, 2012, 10:18:35 am by jessie08 » Logged
Offline Offline
Newbie
View Profile
and this is for the code for controlling the motors
Code:
Chess XY Table by mJusticz
http://instructables.com/member/mjusticz
Feel free to modify this code to your liking, but, should you distribute this software, credit is appreciated
board layout:
7 15 23 31 39 47 55 63
6 14 22 30 38 46 54 62
5 13 21 29 37 45 53 61
4 12 20 28 36 44 52 60
3 11 19 27 35 43 51 59
2 10 18 26 34 42 50 58
1 9 17 25 33 41 49 57
0 8 16 24 32 40 48 56
these numbers are converted to base 8 which gives us some coordinates
#include <AFMotor.h>
#include <Servo.h>
#include <String.h>
const float PINUMBER = 3.14159;
const float GEARDIAMETER = 1.2; //Gear diameter in inches
const float STEPSPERREV = 48; //However many steps per revolution your stepper motors support. For a 7.5 degree/step motor it's 48
const float BOARDSIDE = 24; //playable area of your chess board in inches
float circumference = (GEARDIAMETER * PINUMBER);
float stepsExact = ((BOARDSIDE / circumference) * STEPSPERREV); //Stores the exact, decimal value number of steps
int stepsforlength = stepsExact; //Rounds to a useful number of steps. Margin of error is 7.5 degrees (depending on stepper), so no big deal if its a little off
int stepsforsquare = (stepsforlength/8); //However many steps there are per square
int changey;
int changex;
int byteReceived = 0;
String laststringcoordinate = "";
String stringcoordinate = "";// stores coordinates as a string rather than a number Eg. A3
int lastintcoordinate, intcoordinate; //this stores our coordinates together in one glob that's easy to search. We then split it up
int lastxcoordinate, lastycoordinate;
int xcoordinate, ycoordinate;
char * squares[] = {"a1","a2","a3","a4","a5","a6","a7","a8","b1","b2","b3","b4","b5","b6","b7","b8","c1","c2","c3","c4","c5","c6","c7","c8","d1","d2","d3","d4","d5","d6","d7","d8","e1","e2","e3","e4","e5","e6","e7","e8","f1","f2","f3","f4","f5","f6","f7","f8","g1","g2","g3","g4","g5","g6","g7","g8","h1","h2","h3","h4","h5","h6","h7","h8","\0"};
AF_Stepper xaxis(STEPSPERREV, 2); //set up our motors
AF_Stepper yaxis(STEPSPERREV, 1);
Servo magnetservo;
boolean upordown;
void setup(){
Serial.begin(115200); //begins our connection for debug
magnetservo.attach(9); //Servo_2 on the motor shield
xaxis.setSpeed(15); //sets stepper speed to 75rpm. You may need to adjust this a little if you're having trouble
yaxis.setSpeed(15);
magnetservo.write(175);
void loop(){
if(Serial.available() > 0){
for(int i = 0; i < 2; i++){ //until we have two digits...
byteReceived = Serial.read(); //read the serial port - remember, it comes one digit at a time
laststringcoordinate = laststringcoordinate + byte(byteReceived); //append it to our last string coordinate
//delay(10); //wait for the buffer to fill
byteReceived = Serial.read();//read the serial port
stringcoordinate = stringcoordinate + byte(byteReceived); //append it to our string coordinate
/* if(stringcoordinate.length() > 0 && laststringcoordinate.length() > 0){ //this statement just prints out the coordinates to make sure they're correct
Serial.print(laststringcoordinate);
Serial.print(",");
Serial.print(stringcoordinate);
//This next chunk of code finds the location of each square in its number form, and converts it to base 8 so we can use coordinates
//it's rudimentary search code -- plugging each possibility into our array until we get a match.
for(int i = 0; i < 64; i++){
if(laststringcoordinate.equals(squares[i])){
lastintcoordinate = i;
if(stringcoordinate.equals(squares[i])){
intcoordinate = i;
/////////DEBUG\\\\\\\\\\
//delay(10);
Serial.print(lastintcoordinate); //let's print our coordinates in int form
Serial.print(",");
Serial.println(intcoordinate);
//now we convert those numbers to base 8 to get some useful coordinates
lastycoordinate = lastintcoordinate % 8;
lastxcoordinate = lastintcoordinate / 8;
ycoordinate = intcoordinate % 8;
xcoordinate= intcoordinate / 8;
//delay(10);
Serial.print("(");
Serial.print(lastxcoordinate);
Serial.print(",");
Serial.print(lastycoordinate);
Serial.print(")");
Serial.print(" to ");
Serial.print("(");
Serial.print(xcoordinate);
Serial.print(",");
Serial.print(ycoordinate);
Serial.println(")");
magnetservo.write(175); //puts the magnet down
xaxis.step((stepsforsquare/2), FORWARD, DOUBLE); //Offset to middle of square
yaxis.step((stepsforsquare/2), FORWARD, DOUBLE); //Offset
//delay(1000);
xaxis.step((lastxcoordinate * stepsforsquare), FORWARD, DOUBLE); //goes to our first set of coordinates. Assume we start at 0,0
yaxis.step((lastycoordinate * stepsforsquare), FORWARD, DOUBLE); //goes to our first set of coordinates. Assume we start at 0,0
//delay (3000); //waits for stepper to get to location
magnetservo.write(1); //puts the magnet up
//This code handles a vertical movement of a piece, where dividing to get a slope would give a denominator of 0 and crash the program
changey = (lastycoordinate - ycoordinate) * stepsforsquare; //the absolute value function doesn't work properly with math, so we have to store it in variables first
changex = (lastxcoordinate - xcoordinate) * stepsforsquare;
if(lastxcoordinate == xcoordinate){
Serial.println("vertical");
if(ycoordinate > lastycoordinate){
Serial.println("//delay1");
//delay(1000);
yaxis.step(abs(changey),FORWARD,DOUBLE);
//delay(1000);
if(ycoordinate < lastycoordinate){
Serial.println("//delay2");
//delay(1000);
yaxis.step(abs(changey),BACKWARD,DOUBLE);//we don't want any negative values
//delay(1000);
else if(((lastycoordinate - ycoordinate) / (lastxcoordinate - xcoordinate)) > 0){ //if we need to go up and to the right or down and to the left...
if(lastxcoordinate > xcoordinate){//...down and to the left
Serial.println("downleft");
yaxis.step(abs(changey), BACKWARD, DOUBLE);
xaxis.step(abs(changex), BACKWARD, DOUBLE);
if(lastxcoordinate < xcoordinate){//...up and to the right
Serial.println("upright");
yaxis.step(abs(changey), FORWARD, DOUBLE);
xaxis.step(abs(changex), FORWARD, DOUBLE);
else if(((lastycoordinate - ycoordinate) / (lastxcoordinate - xcoordinate)) < 0){// if we need to go down and to the right or up and to the left...
if(lastxcoordinate < xcoordinate){//... down and to the right
Serial.print("downright");
if(lastxcoordinate > xcoordinate){//... up and to the left
Serial.println("upleft");
else if(lastycoordinate == ycoordinate){ //if we need to go left or right...
if(lastxcoordinate < xcoordinate){ //go right
Serial.println("right");
xaxis.step(abs(changex),FORWARD,DOUBLE);
if(lastxcoordinate > xcoordinate){//go left
Serial.println("left");
xaxis.step(abs(changex),BACKWARD,DOUBLE);
magnetservo.write(175); //puts the magnet back down
xaxis.step((xcoordinate * stepsforsquare), BACKWARD, DOUBLE); //goes to our first set of coordinates. Assume we start at 0,0
yaxis.step((ycoordinate * stepsforsquare), BACKWARD, DOUBLE); //goes to our first set of coordinates. Assume we start at 0,0
//delay(1000);
xaxis.step((stepsforsquare/2), BACKWARD, DOUBLE); //offset back to edge of square
yaxis.step((stepsforsquare/2), BACKWARD, DOUBLE); //offset
changex = 0;
changey = 0;
xcoordinate = 0;
ycoordinate = 0;
lastxcoordinate = 0;
lastycoordinate = 0;
intcoordinate = 0;
byteReceived = 0; }
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Have you contacted the instructable project person with your questions?
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Offline Offline
Newbie
View Profile
yes, but there is no response.  can you help me?
Logged
UK
Offline Offline
Tesla Member
View Profile
You need to be able to wire two stepper motors to a motor shield, and a servo, and 64 reed switches to a multiplexer.
You should be able to find examples of all of those things being done separately.
If you can't do any of them and aren't good enough at Googling to find examples then I suspect you are going to find this project very difficult and you might want to do something easier first - if it involves multiplexers, servos or stepper motors then it will get you closer to being able to tackle this project.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
How about adapting this?
http://www.kitsusa.net/phpstore/html/OWI535-ROBOTIC-ARM-EDGE-1680.html
Puts the motor part into a nice assembly with gripper, without the complexity of having to make a CNC machine.
The site has other versions also.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Newbie
View Profile
For now, we'll try to control the motors using arduino and the reed switches. Its too complex to assemble everything at once. But I still wish to have a diagram. smiley-cry
By the way, is it easier if we are going to use a robotic arm instead?
Thanks so far  smiley
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
I guess arm vs table depends on how big  you want to make things.
Having the pieces move by magnet/electromagnet seems doable - getting the right magnet strength to only move the intended piece seemed to need working out. I guess having pieces spread out helps with that.
With a prebuilt-arm to start, at least the mechanical stuff has been worked out already so you're not taking on quite as much tasking to start. Still have to control four/five motors - spin left/right, main arm up/down, finger arm up down, and pincer open/closed - but limit switches should be in place.
And you could always program in some taunting kind of actions later ...
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Robot arm hacked for Arduino!
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Another interesting looking one
Logged
Offline Offline
Newbie
View Profile
We actually want to make little changes in the project. Out XYZ table will be at the top of our sensory board so we would not have any problem with the magnets. We consider using ceramic magnets because neodymiums are way powerful and expensive.
I will still consider your suggestion guys, and still open for more suggestions though.
Thank you very much.
Logged
Pages: [1]   Go Up
Print
Jump to:
