Loading...
Pages: [1]   Go Down
Author Topic: Tricolor LED Strip  (Read 920 times)
Offline Offline
Newbie
View Profile
Hello Community,
I recently bought this at my local Radio Shack:
http://www.radioshack.com/product/index.jsp?productId=16306856&clickId=489254786&affiliateId=59782&affiliateCustomId=#
I'm a bit confused with this LED strip as it only has 3 Wires coming of it. I think it's 12v, GNG and Data. Does anyone know how I would wire this with an arduino?
Thanks!
Logged
Offline Offline
Newbie
View Profile
Here's a better picture:
https://www.dropbox.com/s/eylotot0jpaqtd1/2012-11-10%2018.58.51.jpg
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Look at that chip U4. What type does it say it is?
Then look up that for using with the arduino.
It is a serial protocol where you send data by waggling the data line to control each of the colored LEDs.
Logged
Offline Offline
Newbie
View Profile
As the LED strip continues each chip & led is incremented. I have U1 -> U5.
Logged
Offline Offline
Brattain Member
View Profile
WWW
Yes I know but all the chips are the same.
You talk to them with a protocol.
What that protocol is depends on the type of chip you have.
If you are not going to tell what type of chip you have then the only chance I have of helping you is if I actually buy that strip myself and look at the chip.
That is not going to happen.
Logged
Offline Offline
Newbie
View Profile
I've found the type of chip. This strip has poor documentation. I'm working with a TM1803 v2.
I'll post back with what ever information I manage to find. I appreciate your help.
Logged
Offline Offline
Brattain Member
View Profile
WWW
Found this if it helps:-
http://www.deskontrol.net/blog/arduino-based-artnet-node-for-led-pixels/
Logged
Offline Offline
Newbie
View Profile
Thank you very much for your help.
Looks like I have some timing issues to work out.
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
I have the same LED strip. Have you gotten anything else figured out?
Logged
Offline Offline
Edison Member
Now, More Than Ever
View Profile
At the RadioShack link there are hotlinks to a ZIP with PDEs and the datasheet for the strip's controller and there's a PDF, too.
It's the "Product Summary" tab, "Downloadable content" (they aren't highlighted - probably so as not to call attention to them and keep consternation and anxiety stoked.)
You have to make a folder to put each of the PDEs into.
I've attached the ZIP and the PDF to this post.
Logged
Don't React -- Read!
Pages: [1]   Go Up
Print
Jump to:
