Author Topic: Array value change unexpectedly over time  (Read 329 times)
Australia
This has had me stumped for a few days now! I've a lot of programming experience but new to C++ and Arduino..
I've an array (_RGBpins) whose values randomly/unexpectedly change over time.
Below is a cut down sketch which replicated the problem with serial debugging.
#include "rgbled.h"
RGBLed rgbled(6,7,8);
//The setup function is called once at startup of the sketch
  Serial.print("started ");
// The loop function is called in an endless loop
  byte white[] = {255,255,255};
  byte black[] = {0,0,0};
  rgbled.tempChange(white);
  delay(3000);
  rgbled.tempChange(black);
rgbled.cpp
#include "rgbled.h"
#include "Arduino.h"
// led pins
byte _RGBpins[3];
// constructor function
RGBLed::RGBLed(byte redPin, byte greenPin, byte bluePin) {
  _RGBpins[0] = redPin;
  _RGBpins[1] = greenPin;
  _RGBpins[2] = bluePin;
  for (byte i = 0; i < 3; i++) {
    pinMode(_RGBpins[i], OUTPUT);
void RGBLed::tempChange(byte rgb[]) {
  Serial.print(" pins:");
      Serial.print(_RGBpins[i]); // values in _RGBpins change randomly!?!
      Serial.print(",");
rgbled.h
#ifndef RGBLED_H_
#define RGBLED_H_
class RGBLed {
public:
                RGBLed(byte redPin, byte greenPin, byte bluePin);
void tempChange(byte rgb[]);
private:
                byte _RGBpins[];
#endif
thanks in advance..
Melbourne, Australia
Online Online
Shannon Member
Lua rocks!
private:
                byte _RGBpins[];
You are putting 3 bytes of data into a zero-sized array. Very bad. Try:
private:
                byte _RGBpins[3];
Online Online
Shannon Member
Lua rocks!
Also, due to the "static initialization order fiasco" you should not be calling library functions from a constructor. Remove the following:
... from the constructor. Make a RGBLed::begin() function, and call that in setup(), like this:
void RGBLed::begin ()
Australia
Thanks heaps Nick!
Haven't had much experience with header files before, didn't realise the size needed to be set there too.
Also I'd noticed some constructor problems earlier, will go with your begin() suggestions thanks!
 smiley
