Topic: 9 wire stepper question (Read 2191 times) previous topic - next topic
Chrispy
Hi, new to the forum, and definitely a newcomer to this subject!
I'm hoping I can get some advice on running a 9 wire stepper motor, pictures attached,
Code 57SH-52A9D 22.5? 0.9deg, JAPAN 16 May 86 DB
I have successfully got two 4 wire steppers running, using a Uno plus a stepper shield,
but I have no idea of where to go with this motor which I'm hoping will have a lot more torque.
I think I have identified the pairs on this motor using the 'easy to turn' test.
All other combinations lock the motor.
Nine wires...
White           1
Mauve   2
Orange   5
Blue           6
Green   4
Brown   3
Yellow   8
Red      7
Black   ?????
I'm scratching my head over  what the 12th wire is for?
Will I be able to hook this up to my '2 servo - 2 stepper - 4 DC motor' Arduino shield?
Your help would be appreciated!
Thanks
Chris
Chagrin
Given the 0.9 degree label I would guess it's a 9 wire unipolar motor. One of those 9 wires (probably black) will have half the resistance to any of the other 8 wires.
Do you have an ohmmeter? Create a chart and start writing down the resistances between each of the wires. The arrangement should become clear pretty quickly and should be much more reliable than your "hard-to-turn" method.
As far as driving the motor goes you just need 8 transistors. You can find lots of examples of 5 wire stepper wiring (usually using a ULN2003); you just have twice as many coils.
Chrispy
Thanks for the suggestion; I've created the chart but I'm not sure what it's telling me?
Can you see a meaningful pattern?
Thanks
Chris
Chagrin
Yes, it's a unipolar motor. The white wire would be connected to ground and each of the remaining wires would be energized (connected to ~5V) in sequence to make the motor turn.
Take a look at this tutorial on 5 wire steppers to understand the internal layout. For the stepper in the example, the red wire would be the same as your white wire.
dc42
Alternatively (and probably easier), connect the white wire to your positive supply, and use transistors or a ULN2803A to connect each of the other wires to ground in turn.
Chrispy
Thank you!
There are moments when I ask myself why I am going down this path.
Than goodness I'm retired and have the time.
I feel as though I'm starting a marathon while I'm still learning to crawl!
Cheers
Chris
