Loading...
Pages: [1]   Go Down
Author Topic: Datalogger and 2 Accelerometers  (Read 550 times)
Offline Offline
Newbie
View Profile
So this is my second post in this forum. At first I was asking about being able to use I2C and SPI protocols simultaneously and was told that it was possible. Now the problem is that i got the 2 accelerometers to work together (both I2C) and i am able to initialise the SD card, but when i try to open a file and write, the program just freezes. This is the part of the code having to do with the SD card:
//Initialize Card in void setup()
  if (!SD.begin(CS_pin))
      Serial.println("Card Failure");
      return;
  Serial.println("Card Ready");
//Open file in void loop() after filtering the 6 values for the acc. and then outputting them to serial
    int output1=movingAvarageFilter.process(acc_Front.value.x);
    int output2=movingAvarageFilter1.process(acc_Front.value.y);
    int output3=movingAvarageFilter2.process(acc_Front.value.z);
    int output4=movingAvarageFilter3.process(acc_Rear.value.x);
    int output5=movingAvarageFilter4.process(acc_Rear.value.y);
    int output6=movingAvarageFilter5.process(acc_Rear.value.z);
    Serial.print(output1); Serial.print(",");
    Serial.print(output2); Serial.print(",");
    Serial.print(output3); Serial.print(",");
    Serial.print(output4); Serial.print(",");
    Serial.print(output5); Serial.print(",");
    Serial.println(output6);
   File logFile = SD.open("LOG.csv", FILE_WRITE);
  if (logFile)
    logFile.println("Hello");
    logFile.close();
    Serial.println("Couldn't open log file");
Logged
Miramar Beach, Florida
Offline Offline
Faraday Member
View Profile
Maybe you are running out of SRAM? Which Arduino model are you using? The SD.open() function requires a bit of SRAM (500 bytes).
You might want to try using the F() function to keep the strings in program memory. That may help.
Code:
      Serial.println(F("Card Failure"));
      return;
  Serial.println(F("Card Ready"));
Logged
Offline Offline
Newbie
View Profile
I'm using a Duemilanove clone board. Tomorrow my Leonardo should be arriving in the post so maybe if i try it on it, it'll work. But for now i'll try using the F() function. Thanks man
Logged
Offline Offline
Newbie
View Profile
IT WORKED!!! Thanks a lot smiley-grin
Logged
Pages: [1]   Go Up
Print
Jump to:
