Topic: Are these 2 code identical in function ? (Read 1 time) previous topic - next topic
stinkyled
Nov 11, 2012, 12:06 pm Last Edit: Nov 11, 2012, 12:23 pm by stinkyled Reason: 1
Hi everyone , I am so new to arduino that I could not tell what is the difference between these 2 codes , code 2 is written by me but it doesn't have the solid feel as code 1.
Can you please take a look ?
Code 1
Code: [Select]
const int LED = 13; // the pin for the LED
const int BUTTON = 7; // the input pin where the
// pushbutton is connected
int val = 0; // val will be used to store the state
// of the input pin
int old_val = 0; // this variable stores the previous
// value of "val"
int state = 0; // 0 = LED off and 1 = LED on
pinMode(LED, OUTPUT); // tell Arduino LED is an output
pinMode(BUTTON, INPUT); // and BUTTON is an input
void loop(){
val = digitalRead(BUTTON); // read input value and store it
// yum, fresh
// check if there was a transition
if ((val == HIGH) && (old_val == LOW)){
state = 1 - state;
delay(10);
old_val = val; // val is now old, let's store it
if (state == 1) {
digitalWrite(LED, HIGH); // turn LED ON
digitalWrite(LED, LOW);
Code 2
Code: [Select]
const int led =13;
const int button =7;
int state = 0;
  pinMode(led,OUTPUT);
  pinMode(button,INPUT);
  if(digitalRead(button))
      delay(10);
      state = 1-state;
    if(!state)
    digitalWrite(led,LOW);
     digitalWrite(led,HIGH);
johnwasser
Not quite.  Code 1 will toggle the LED once, each time the button is pushed.  Code 2 will toggle the LED at about 100 times per second as long as the button remains pressed.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
robtillaart
When comparing code you must be the compiler
- strip of the comments
- variable names only need to be distinct
- fill in the #defines/macros
- then start comparing...
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
stinkyled
Awesome !! thank you for pointing that out :)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
