Topic: Sampling rate verification (Read 2908 times) previous topic - next topic
dc42
You code uses the conversion complete interrupt to trigger a new conversion. By then you've probably missed the boat and need to wait an extra ADC clock cycle or two to start the new conversion. I think you need to put the ADC in continuous conversion mode to achieve the quoted maximum conversion rate.
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
dhenry
I got 31128hz.
You can do the math but you will find that it takes 250 ticks to finish adc and to flip the pin. So the pin flip has a period of 500 ticks -> 32Khz.
dhenry
The highest I can get is 38647hz (latency is not an issue here).
That confirms the 77k sample rate in the datasheet.
chung
Bingo! I switched to free-running mode and the frequency rose up to 38.46kHz!
chung
#19
Nov 11, 2012, 04:10 pm Last Edit: Nov 11, 2012, 04:37 pm by chung Reason: 1
I got 31128hz.
Why do I get 29.4kHz on single conversion mode?  :~ :0
Update...
OK, I figured out why I get a lower frequency... The signal I measure with my oscilloscope is noisy. Maybe, some capacity creates what is shown on the attached image.
After processing the data with Matlab, I also get 31kHz for the single conversion mode and 40.7kHz for the free running mode.
dhenry
Hopefully by now you have figured out why the falling edge isn't so sharp.
chung
#21
Nov 11, 2012, 05:38 pm Last Edit: Nov 11, 2012, 05:53 pm by chung Reason: 1
Yes, I just figured it out. I had connected a LED (and a resistor) between the output of the pin and the GND  smiley-lol. I removed the LED and now I get a nice square wave @38.17kHz.
Update: FIY: The highest achievable rate (wrt the generated pulse) in free-running mode was 121.4kHz.
