Pages: [1] 2   Go Down
Author Topic: Sampling rate verification  (Read 403 times)
Arduino Rocks!
How can I verify with an oscilloscope the sampling rate on an Arduino Uno rev3.? I want to generate a pulse every time a conversion is done. Here is my code:
#include <avr/io.h>
#include <avr/interrupt.h>
volatile uint16_t myMeasurement;
int main(void)
  DDRC &= ~(1<<DDC0); // Pin A0 as Input
  DDRD |=  (1<<PIND7);//Pin 6 as output
  ADCSRA |= 1<<ADPS2; // Prescaler=16, i.e. 1MHz
  ADMUX |= 1<<REFS0 | 1<<REFS1; //Internal 1.1V Ref used
  ADCSRA |= 1<<ADIE; // Enable the interrupt
  ADCSRA |= 1<<ADEN;// Enable the ADR
  sei();// Enable Interrupts (Global)
  ADCSRA |= 1<<ADSC;//start first conversion
  while(1){  //stay alive
// The interrupt method
ISR(ADC_vect)
  uint8_t lowPart = ADCL;
  myMeasurement = ADCH<<8 | lowPart;
  ADCSRA |= 1<<ADSC;//trigger new conversion
  PIND ^= 1<<PIND6;//Flip pin 6 on arduino
This piece of code, generates a pulse of 29.41kHz on pin 6 - far from the expected 0.5MHz according to the prescaling division factor chosen.  A prescaling factor of 4 yields a pulse of 75.8kHz while 2 yields 100kHz. Is there a way to output a pulse at the frequency of the sampling? Is there a way to make is go faster?
An Arduino development board costs €20~60. A pack of 20 Zener diodes to protect your board from almost certain damage costs less than €1...
UK
What a host of balls she had seen: gaity, the brass buttons...
I know next to nothing about the internals of the Atmel ADC, so I can't comment on your settings.  One thing I can comment on though - are you taking into account the number of instructions taken to process the interrupt?
ISR(ADC_vect)
 154:   1f 92           push    r1
 156:   0f 92           push    r0
 158:   0f b6           in  r0, 0x3f    ; 63
 15a:   0f 92           push    r0
 15c:   11 24           eor r1, r1
 15e:   2f 93           push    r18
 160:   3f 93           push    r19
 162:   4f 93           push    r20
 164:   8f 93           push    r24
 166:   9f 93           push    r25
 168:   ef 93           push    r30
 16a:   ff 93           push    r31
 16c:   20 91 78 00     lds r18, 0x0078
 170:   40 91 79 00     lds r20, 0x0079
 174:   94 2f           mov r25, r20
 176:   80 e0           ldi r24, 0x00   ; 0
 178:   30 e0           ldi r19, 0x00   ; 0
 17a:   82 2b           or  r24, r18
 17c:   93 2b           or  r25, r19
 17e:   90 93 da 01     sts 0x01DA, r25
 182:   80 93 d9 01     sts 0x01D9, r24
 186:   ea e7           ldi r30, 0x7A   ; 122
 188:   f0 e0           ldi r31, 0x00   ; 0
 18a:   80 81           ld  r24, Z
 18c:   80 64           ori r24, 0x40   ; 64
 18e:   80 83           st  Z, r24
 190:   89 b1           in  r24, 0x09   ; 9
 192:   90 e4           ldi r25, 0x40   ; 64
 194:   89 27           eor r24, r25
 196:   89 b9           out 0x09, r24   ; 9
 198:   ff 91           pop r31
 19a:   ef 91           pop r30
 19c:   9f 91           pop r25
 19e:   8f 91           pop r24
 1a0:   4f 91           pop r20
 1a2:   3f 91           pop r19
 1a4:   2f 91           pop r18
 1a6:   0f 90           pop r0
 1a8:   0f be           out 0x3f, r0    ; 63
 1aa:   0f 90           pop r0
 1ac:   1f 90           pop r1
 1ae:   18 95           reti
That's 26 instructions from the point the interrupt routine is triggered to when the next ADC sample is started.
United Kingdom
Looks like you are assuming that the ADC only takes one clock do to a conversion, whereas it actually takes more (around 12 AFAIR - check the datasheet).
[quote]This piece of code, generates a pulse of 29.41kHz on pin 6 - far from the expected 0.5MHz ...
.5Mhz means 2u or 32 ticks at 16MIPS. Your isr latency will take 10 - 20 ticks and that doesn't leave much to execution. One way to check for latency is to eliminate all code other than the pin flipping statement and see if you gain speed. If you do, latency is the issue.
Having said, 29.41khz sounds too low.
Arduino Rocks!
You mean, I should write my code in such a way that the occurring number of instructions is lower? Unless I go down to the assembly level, I don't think this is possible. But, I have the feeling that there must be a way...
Austin, TX
CMiYC
From the ATmega datasheet:
A normal conversion takes 13 ADC clock cycles.
A forum post that might interest you:
http://arduino.cc/forum/index.php/topic,6549.0.html
www.cmiyc.com - A guide to being an Enginerd
Arduino Rocks!
If this is the case, what is the prescaler all about? And what is the meaning of being able to sample every 1us (ie 1MHz) or less if it takes more just to get the result?
UK
I don't know much about avr-gcc, but there might be attributes to the isr routine that control what gets stored in the stack and what doesn't - that could reduce the number of registers and such being saved and save some time.
Also, don't forget that the output pin will be running at *half* the frequency of the sample rate.  You switch on with one sample, and switch off with the next sample, so for 0.5MHz sample rate you should be getting 0.25MHz pin frequency.
UK
The datasheet:
You have a maximum of 15ksps at full resolution, or 76.9ksps at "normal" resolution.
How you're trying to get 0.5msps (500ksps) out of it I don't know.
To get that kind of rate I use a dsPIC at 80MHz (40 MIPS) and DMA to do the actual sampling direct to memory.
« Last Edit: November 11, 2012, 09:19:53 am by majenko » Logged
Arduino Rocks!
So the frequency I should expect is (at most):
f_sampling = f_cpu/prescaling
f_pulse = f_sampling/(13*2)
Is that right?
I think I understood your confusion now. The adc prescaler selects the adc clock (to be 1/16 in  your case) but each conversion may take multiple (around 15) ticks of the adc clock to complete.
UK
The ADC is a "successive approximation" type.  Each tick of the ADC clock resolves the sampled voltage down to a higher resolution and accuracy.  You can sample at a lower resolution, which requires less clock ticks to calculate that number of bits, and thus sample faster.  You still can't get a sample at just one clock tick - for that you need a "flash" type ADC, and they cost big bucks.  They're used in video systems and allow giga-samples-per-second.
Arduino Rocks!
OK, I got it now... In the document "AVR120: Characterization and Calibration of the ADC on an AVR" it is stressed that:
Since one conversion takes 13 ADC clock cycles, a maximum ADC clock of 1
MHz means approximately 77k samples per second. This limits the bandwidth in
single-ended mode to 38.5 kHz, according to the Nyquist sampling theorem.
But, the frequency I achieve is not 38.5kHz; it is 29.4kHz which means that either my conversion takes longer or that the directive PIND ^= 1<<PIND6; takes 4 cycles to execute. Does any of these hypotheses make sense?
it is 29.4kHz
Yes (I got 31khz) but that's for two samples (because you flip the pin for each sampling and two flips complete a period) -> sampling is done about close to 60khz. That's very close to the 77khz figure in the datasheet (without considering latency).
Arduino Rocks!
Yes (I got 31khz)
You mean, you tried my code and you got 31kHz? And I get 29.4kHz?! This is scandalous! I'll ask for my money back!  smiley-razz
True. But, it's not that close to 77kHz. And I would like to fathom the reasons for this discrepancy. If I didn't have an oscilloscope for example, could I have predicted the actual sampling frequency at a good accuracy?
Pages: [1] 2   Go Up
