Topic: Free RTOS (Read 5444 times) previous topic - next topic
skyjumper
I see that Free RTOS supports SAM 3X series. I have never ported an RTOS, does anyone have an idea how difficult it might be to make Free RTOS run on the Duo?
FreeRTOS
#1
Nov 12, 2012, 10:05 pm Last Edit: Nov 12, 2012, 10:08 pm by FreeRTOS Reason: 1
FreeRTOS is already running on the Due. I will post references within days.
Regards,
Richard http://www.freertos.org/Atmel_SAM3_SAM3X-EK_SAM3S-EK2_RTOS_Demo.html
skyjumper
Fantastic!  I can't wait! Thanks!
FreeRTOS
There is now a FreeRTOS project for the Arduino Due in the latest Atmel Software Framework (ASF) release, available through the Atmel Gallery
Regards,
Richard (FreeRTOS)
arduino2012
Regards,
Richard (FreeRTOS)
I have the latest Atmel Software Framework (ASF) but I can't find any freeRTOS integration.
Does anybody know how to use freeRTOS in Atmel Studio?
FreeRTOS
From the Atmel Studio menu:
File->New->Example Project From ASF
In the dialogue box that opens:
1) On the left, select the kit.  Various SAM3 and SAM4 kits have FreeRTOS demo, the drivers that are demonstrated depends on the kits.
2) For example, expand Arduino Due (which is at the top of the list of kits).
3) In the list of projects you will see "FreeRTOS Peripheral Control Example" - selecting that will create the project (I have not tried it on the Arduino hardware and am not sure which interfaces it will demonstrate).
4) Read the instructions at the top of the file that contains the definition of main() - the examples use FreeRTOS+CLI which is free for use on Atmel microcontrollers.
If you create a project for the SAM4S or SAM3X EKs then you will see most (all) of the drivers demonstrated.
Regards,
Richard (FreeRTOS)
ctbenergy
#6
Mar 05, 2013, 11:08 pm Last Edit: Mar 05, 2013, 11:14 pm by ctbenergy Reason: 1
Hi Richard,
Thanks for the detailed description.
I have tried "FreeRTOS Peripheral Control Example" on the Arduino Due and it works.
Atmel has provided an application note for FreeRTOS:
Atmel AVR10008: ASF Specific FreeRTOS Functionality for Peripheral Control
http://www.atmel.com/Images/doc42049.pdf
Another possibility to integrate FreeRTOS for Arduino Due/X:
Atmel Studio 6 (Version 6.0.1996 Service Pack 2)
Atmel Studio Framework 3.5.1
1. File -> New -> Project -> C/C++ -> ArduinoBoards -> Arduino Due/X ATSAM3X8E
2. Add ASF Modul "FreeRTOS mini Real-Time Kernel (7.3.0)" in the Atmel Software Framework Wizzard (ASF 3.5.1.188)
3. Workaround for bug in ASF Modul "FreeRTOS mini Real-Time Kernel" (error "portmacro.h" No such file or directory)
   Project -> Settings -> Toolcain -> ARM/GNU C Compiler -> Directories -> Include Paths ->
   Add Item "../src/asf/thirdparty/freertos/freertos-7.3.0/source/portable/gcc/arm_cm3"
Regards,
Ewald
