Loading...
Pages: [1]   Go Down
Author Topic: GLCD to Mega2560  (Read 364 times)
Singapore
Offline Offline
Jr. Member
View Profile
Hi, I am having error "GLCD initialization Failed: RESET wait Timeout (status code: 2)" when running the GLCDdiags.
I have checked all my wirings as below
Mega 2560 pin   LCD description   LCD pin no.
-   Supply voltage (5V)   1
-   Ground (0V)   2
-   Operating voltage (variable)   3
22 ~ 29   Data bit 0 ~ 7   4 ~ 11
33   Chip select for IC1   12
34   Chip select for IC2   13
Not connected   Reset signal   14
35   Read/ Write signal   15
36   Data/ Instruction signal   16
37   Chip enable signal   17
-   Operating voltage (variable)   18
-   Backlight power supply   19
-   Backlight power supply   20
Logged
Singapore
Offline Offline
Jr. Member
View Profile
I keep getting the same display on my LCD....
Logged
Singapore
Offline Offline
Jr. Member
View Profile
Can anyone please help me?
I am using Mega 2560 with GLCD GDM12864HLCM
Logged
Singapore
Offline Offline
Jr. Member
View Profile
I have cleared the error "GLCD initialization Failed: RESET wait Timeout (status code: 2)" but now I got another error :
Diag Loop: 1
Initializing GLCD
Displaying ChipSelect Screens
Walking 1s data test
 Compare error: 0 != 10
TEST FAILED
Please help
Logged
Dallas, TX USA
Offline Offline
Edison Member
View Profile
These types of errors are almost always due to incorrect wiring.
A few questions:
1) what did you change in the wiring that eliminated the RESET timeout?
You have not described how you have hooked up the contrast pot.
2) How have you hooked up the contrast pot?
What is hooked up to Vo (glcd pin 3) and Vee (glcd pin 18)
3) can you post the full sequence of the diag output?
From start to finish of 1 loop. It contains other useful information.
(make sure to re-wire the glcd RESET as described below first)
Not all displays can work with the glcd RESET signal floating.
Most do but some require a pullup to vcc and some require a full reset transition
before they will initialize properly.
The easiest for now is to hook up a pin from the mega to allow the glcd library to
control the GLCD reset line.
Once things are working, it may be possible to eliminate this additional pin.
To enable s/w controlled RESET you must edit the pin configuration file.
It is in glcd/config/ks0108_Mega.h
You have to uncomment the glcdRES pin definition.
Change this:
Code:
//#define glcdRES         30    // Reset Bit
to this:
Code:
After you make that change run the diags and post the text output here.
--- bill
Logged
Pages: [1]   Go Up
Print
Jump to:
