Topic: Vin+2 ground pins oxidation (Read 658 times) previous topic - next topic
btricha2
I use my arduino quite a bit, and have noticed that the two ground pins beside Vin, and the Vin pin have slowly accumulated oxidation inside their female headers. The arduino seems to work fine, but I'm not sure what is causing this. Typically I use 2 or 3 peripherals depending on the project
, all of which seem to be functioning properly. Does anyone have any idea as to what is the likely cause of this?
btricha2
James C4S
Are you sure that isn't rapidly burned plastic?
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
MarkT
btricha2
I think it probably is burned plastic. What I'm not sure about are the kinds of things would make that area, specifically, to overheat. Overuse? too high of a current draw from the devices, etc. I usually use those two grounds, for devices, but never use the Vin pin
thanks for the input!
