Loading...
Pages: [1] 2   Go Down
Author Topic: Can I replace the FT232R with FT231X/FT230X?  (Read 1185 times)
Israel
Offline Offline
Full Member
View Profile
Was thinking of using the FT231X or FT230X instead of the FT232R for USB-UART connection since it's almost %50 cheaper.
Anything I should know before using the new chip?
« Last Edit: November 11, 2012, 03:49:18 pm by szangvil » Logged
Offline Offline
Jr. Member
View Profile
"What’s the difference between the FT232R, FT230X and FT231X?
Answer:  All three ICs provide a USB-to-UART bridge function.  In addition to the usual TXD and RXD serial data signals, the FT232R and FT231X provide a full complement of modem handshake signals.  We call this a “Full UART”.  The FT230X does not have the full complement of handshake signals and is targeted at applications where a simplified handshake scheme is sufficient (RTS/CTS, Xon/Xoff or none).  We assigned the designation of “Basic UART” for the simplified handshake. The advantage of the FT230X is that because it has less handshake signals, it comes in a smaller package.
 The FT230X and FT231X are members of the newly released X-Chip series of USB device (slave) interface ICs.  One primary feature of the X-Chip series is its support for the USB Battery Charging specification by providing signals to indicate when the chip is connected to a USB Dedicated Charging Port (DCP).  A DCP allows higher charging currents for battery-powered devices, meaning reduced charging times. The X-Chip Series targets smaller device footprints, lower power, and lower system costs as a result of its extended feature set and attractive unit prices."
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Short answer, AFAIK there's no reason not to use them. I've just laid out aboard with the FT232R but am thinking of changing it to use the 230X.
One difference seems to be that the X chip needs some RC components on the USB + and - inputs. At least according to the recommended schematic.
EDIT: Another difference, nobody seems to have stock of the 230X. That's a worry if this is a product.
______
Rob
« Last Edit: November 11, 2012, 03:59:13 pm by Graynomad » Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Well if you are using an Arduino that requires the auto-reset feature to work you do need to have the USB UART control signals, either RTS or DTR as that is how the arduino IDE resets the board prior to a upload operation.
Lefty
Logged
Offline Offline
Jr. Member
View Profile
Short answer, AFAIK there's no reason not to use them. I've just laid out aboard with the FT232R but am thinking of changing it to use the 230X........
______
Rob
I agree with Rob....you should use them, and I can't find the 230X either!
Logged
Offline Offline
Jr. Member
View Profile
Actually, you might want to try to find the FT230X at Mouser Electronics (mouser.com) because they have an extremely wide variety of components.
Logged
Israel
Offline Offline
Full Member
View Profile
Well, I see now that the 230X has no DTR, only CTS... the 231X has DTR
Logged
Offline Offline
Tesla Member
View Profile
WWW
Good point Lefty, the 230 only has RTS, that used to be OK for auto reset I think but I'm not sure these days. The 231 has all the signals so presumably it will toggle DTR in the same way as the 232 does.
Quote
I just did an Octopart search, it shows no stock anywhere. So I checked Mouser directly, 8000 in stock at $2.75. I guess Octopart isn't up to date although to be fair it's marked as a new product. Octopart normally my first port of call when looking for a part.
______
Rob
Logged
Offline Offline
Brattain Member
View Profile
Quote
______
Rob
I believe for legacy reasons that IDE and/or AVRDUDE pulses both RTS and DTR to initate the auto reset function.
Lefty
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
(some redundancy here)
The Duemilanove used RTS thru a resistor (which was not installed) or DTR thru a cap to create a reset.
http://arduino.cc/en/uploads/Main/arduino-duemilanove-schematic.pdf
If RTS is still output, it would seem that the FT230X could work.
http://www.ftdichip.com/Support/Documents/DataSheets/ICs/DS_FT230X.pdf
FT231X still supports DTR
http://www.ftdichip.com/Support/Documents/DataSheets/ICs/DS_FT231X.pdf
Be a nice price drop from the $4.50 for the FT232RL
http://www.mouser.com/ProductDetail/FTDI/FT230XS-R/?qs=sGAEpiMZZMvVkErl6zY%252bqR%252b6A%252bu%2f1HB5  $2.04
http://www.mouser.com/ProductDetail/FTDI/FT231XS-R/?qs=sGAEpiMZZMvVkErl6zY%252bqfBUiQa5NfR7  $2.12
http://www.mouser.com/ProductDetail/FTDI/FT232RL-REEL/?qs=sGAEpiMZZMs5ceO8zL%252bTxyQLQIH6hE7q  $4.50
leadless packages appear to be in stock, SSOP parts not.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Israel
Offline Offline
Full Member
View Profile
I'll go with the 231X. Where can I download its EagleCad part? The latest version has only 232 and 230...
Logged
Offline Offline
Jr. Member
View Profile
Im not sure, but try
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en537026&redirects=cad
Logged
Offline Offline
Jr. Member
View Profile
If the site I suggested does not work, I do not have a clue on where else to go....We might have to do some research on it.
Logged
Offline Offline
Tesla Member
View Profile
WWW
Make your own part. Don't ask me how though because I don't use Eagle, but it's usually a pretty easy procedure with these programs...oh hang on, we're talking about Eagle here smiley
______
Rob
Logged
Israel
Offline Offline
Full Member
View Profile
Couldn't find a part... I guess I could take some other SSOP-20 part and edit it...
Logged
Pages: [1] 2   Go Up
Print
Jump to:
