Topic: Keyboard Sound Effects (Read 938 times) previous topic - next topic
Zack_Johnston
Hi everyone! I am trying to make many sound effects for a small keyboard or piano, and I am running into trouble.
I have already made a code for a trumpet effect, but I want to make some others and I just cant get them right.
If someone could help me modify the trumpet code to make a new one, that would be great. Thank you! Here is the code:
Code: [Select]
/* PWM Melody via DCB...Trumpet effect*/
//pin 10 pwm sound with pitch and volume control
#define piezoPin 10
#define minVol 1
#define maxVol 128
void setup(){
  pinMode(piezoPin,OUTPUT);
  pinMode(9,OUTPUT);
  TCCR1A = (1 << COM1A1) | (1 << COM1B1 | 1 << WGM10);// sets timer control bits to PWM Phase and Frequency Correct mode
  TCCR1B = 0x12; // sets timer control bits to Prescaler N = 8
  analogWrite(piezoPin, 127); //something less than full volume
int length = 15; // the number of notes
char notes[] = "fffffffffffffff "; // type in any notes to a song
int beats[] = { 1, 1, 2, 1, 1, 2, 1, 1, 1, 2, 1, 4 };
int tempo = 450;
void playNote(char note, int duration) {
  char names[] = { 'c', 'd', 'e', 'f', 'g', 'a', 'b', 'C', ' ' };
  int tones[] = { 1915, 1700, 1519, 1432, 1275, 1136, 1014, 958, 30 };
  int d = duration;
  // play the tone corresponding to the note name
  for (int i = 0; i < 9; i++) {
    if (names[i] == note) {
      OCR1A=tones[i];
      //attack
      for(int x = minVol; x < maxVol;x*=2){
        analogWrite(piezoPin, note == ' '?minVol:x);
        delay(10);
        d-=10;
      //decay
      int x = maxVol;
      while(d >= 2){
        x-=1;
        if(x<minVol) x = minVol;
        delay(5);
        d-=5;
      analogWrite(piezoPin, minVol);
      delay(2);
  for (int i = 0; i < length; i++) {
     playNote(notes[i], beats[i] * tempo);
DuaneB
   You should try a more complex synth engine, this one has four voices with independent envelopes, that will give you everything from a snare drum to a flute.
http://rcarduino.blogspot.com/2012/08/the-must-build-arduino-project-illutron.html
If you check the RCArduino video channel over the next few days I will publish a full demonstration video of my own 5 dollar keyboard project -
http://rcarduino.blogspot.com/2012/10/five-dollar-synthesiser.html
This has a less complicated engine but still makes some big sounds.
Duane B
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
Zack_Johnston
Thank you very much DuaneB, I will definitely use this :)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
