Topic: Read Water Level Sensor Data with c# (Read 2652 times) previous topic - next topic
cyberz7
Nov 12, 2012, 10:52 am Last Edit: Nov 13, 2012, 05:28 am by cyberz7 Reason: 1
hi all .
i want to read analog data from the water level sensor in arduino and in C# application to get data from the analog reading and display to richtextbox in C#
here is the C# code :
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using System.IO.Ports;
namespace MenuUtama
   public partial class Form1 : Form
       SerialPort ser = new SerialPort();
       public Form1()
           InitializeComponent();
       private void comboBox1_SelectedIndexChanged(object sender, EventArgs e)
       private void Form1_Load(object sender, EventArgs e)
           string[] availablePorts;
           availablePorts = SerialPort.GetPortNames();
           for (int i = 0; i < availablePorts.Length; i++)
               comboBox1.Items.Add(availablePorts[i]);
           richTextBox1.Text = " WELCOME ";
       private void button1_Click(object sender, EventArgs e)
                   ser.PortName = comboBox1.Text;
                   ser.Open();
                   ser.Write("1");
                   ser.Close();
       private void button2_Click(object sender, EventArgs e)
               ser.Open();
               ser.Write("2");
               ser.Close();
       private void richTextBox1_TextChanged(object sender, EventArgs e)
here is the Arduino code :
int Relay = 3;
 pinMode(Relay, OUTPUT);
 while (Serial.available() == 0);
 int nilai = Serial.read()-'0';
 if (nilai == 1)
     Serial.println(analogRead(A10));
     digitalWrite(Relay, HIGH);
 else if (nilai == 2)
     digitalWrite(Relay, LOW);
thanks before for your help :)
robtillaart
#1
Nov 12, 2012, 09:41 pm Last Edit: Nov 12, 2012, 09:43 pm by robtillaart Reason: 1
Please use the #button when posting code to apply the right tags . The code is more readable and easier to debug etc
You can modify you post and select the code part (each separately) and press the # button ,
Thank you.
The problem is that the C# application does not read any serial data.
2 seconds of google
- http://www.dreamincode.net/forums/topic/35775-serial-port-communication-in-c%23/ -
- https://msmvps.com/blogs/coad/archive/2005/03/23/SerialPort-_2800_RS_2D00_232-Serial-COM-Port_2900_-in-C_2300_-.NET.aspx  - <<<<<<<< this is simpler !!!
Rob Tillaart
cyberz7
hehe .
sorry .
i am new in this forum  :(
thank you very much for your help.
if i use serial.println in arduino code without input from c# app, i can read via serial monitor the value
but if i use c# app to run the arduino code, when i look at serial monitor, there is no value, empty
why is that ?
robtillaart
That is probably because when the data is read from the serial port by an application it is removed and therfore
it is not available any more for a second application that also (tries to) read from that port.
Rob Tillaart
