Topic: Play mp3 (Read 8433 times) previous topic - next topic
2ndattempt
Hi, im making a class project and i need some help about playing mp3 files with arduino.
I would like play only one music track, use one sensor and one dc motor, everything on an Arduino UNO shield. I was taking a look on music shield (Seeed/Sparkfun), but im not sure if it use all of the PWM pins for his own work.
I saw this too: http://hackerspace-ffm.de/wiki/index.php?title=SimpleSDAudio
Its possible work with this example using Mac?
what you recomend me?
Thank you very much
2ndattempt
http://hackerspace-ffm.de/wiki/index.php?title=Datei:SSDA_Arduino_Ethernet.jpg
can you say to me what hardware is used here?
majenko
That project uses PWM to emulate an audio waveform.  That PWM signal is passed through a low-pass filter to remove the high frequency switching signal and leave an approximation of an audio waveform behind.
It'll be "average" at best.  Also, it uses about 80% of the Arduino's available RAM just to run the audio, and integrating it with other things will be tricky as it needs to run its worker function all the time.
2ndattempt
Thanks Majenko. Do you think that i will have the same power problem using one shield like this: https://www.sparkfun.com/products/10628?
majenko
That shield is a kind of half-way house.
It still uses the Arduino to read the mp3 data from the SD card and send it to the mp3 decoder chip, but because mp3 data is so heavily compressed there is much less data involved, and so the Arduino is more available for doing other things.  Audio quality will be considerably better than a low-pass filtered PWM signal generated by the Arduino, but not as high quality as an uncompressed format player (purely because mp3 is a lossy codec, so you lose audio definition with it).
2ndattempt
#5
Nov 13, 2012, 12:07 am Last Edit: Nov 13, 2012, 12:14 am by 2ndattempt Reason: 1
Thank you again Majenko!
But im wondering one new question... Okey, this shield gives more range to Arduino for works on other things while the first is playing the audio, but how this schema shows: http://dlnmh9ip6v2uc.cloudfront.net/datasheets/Dev/Arduino/Shields/MP3%20Shield-v13.pdf
This music shield use all the grounds and the 5V pin too. It would be possible feed a motor and this shield at same time?
Thank you very much!!
majenko
Yes.  You can connect as many devices in parallel to the power and ground pins as the current limit of the power source / voltage regulator will allow.
How you connect the wires is up to you - you could solder direct to the shield's ground and 5V pins, or insert a prototyping shield in between with stackable headers, etc.
