« on: November 12, 2012, 08:57:50 am » |
I wanna use a POT to control the time of a certain function and for the life of me i can't work out how to get the POT to control the time could someone try to explain it to me (no code if you can help it)
Note; already read the "BlinkWithoutDelay" just wanna adapt it slightly
« Reply #1 on: November 12, 2012, 09:07:15 am » |
Forget about the pot portion: can you control the time of a certain function?
Once you have that figured out, try to read the pot's value and then use that value to control the time of a certain function.
UK
« Reply #2 on: November 12, 2012, 09:15:09 am » |
The analogRead will return a value in the range 0 .. 1023. If this isn't a convenient range of values, you could use the "map" function to get it to more convenient units, or, as you did in your LED dimmer, just use simple arithmetic.
Plug the resulting value into the "interval" variable in blink-without-delay.
« Reply #3 on: November 12, 2012, 09:20:04 am » |
that's what i ended up doing but not sure if it works (as i have no cable can't tell if it's working) and i don't wanna use interputs in my programme just yet
UK
« Reply #4 on: November 12, 2012, 09:30:57 am » |
You're over-thinking - user-defined interrupts are not part of this problem.
South Texas
« Reply #5 on: November 12, 2012, 11:44:27 am » |
Read the POT using analog in. Write or scale that value into the variable you use in your time delay loop.
No need for interrupts or other complex processing. Every time through loop read the POT and update the variable with the delay time.
« Reply #6 on: November 13, 2012, 04:46:40 pm » |
no idea how to scale that value, i've used "analogeRead" but doesn't work
UK
« Reply #7 on: November 13, 2012, 04:50:56 pm » |
i've used "analogeRead" but doesn't work And that means what exactly? (The compiler expects you to spell it correctly, if that's what you meant) Scaling usually involves an arithmetic function.
« Last Edit: November 13, 2012, 04:53:16 pm by AWOL »
« Reply #8 on: November 13, 2012, 04:56:50 pm » |
i've used "analogeRead" but doesn't work And that means what exactly? (The compiler expects you to spell it correctly, if that's what you meant) Scaling usually involves an arithmetic function. using the "analogeRead()" read in the pot value, but i don't know what to devid the value by to get the scale right
UK
« Reply #9 on: November 13, 2012, 04:58:14 pm » |
How do you normally divide something?
« Reply #10 on: November 13, 2012, 04:59:48 pm » |
by using " / "
UK
« Reply #11 on: November 13, 2012, 05:01:55 pm » |
So what's the problem? Did you read reply #2?
