Author Topic: COmpiler issue  (Read 252 times)
Hello!
I am having a compiling issue.  When I try to compile the example servo code that comes with the IDE, I get this error:
Sweep.cpp.o: In function `__static_initialization_and_destruction_0':
C:\Users\Owner\AppData\Local\Temp\build1200514424625972248.tmp/Sweep.cpp:8: undefined reference to `Servo::Servo()'
Sweep.cpp.o: In function `loop':
C:\Users\Owner\AppData\Local\Temp\build1200514424625972248.tmp/Sweep.cpp:23: undefined reference to `Servo::write(int)'
C:\Users\Owner\AppData\Local\Temp\build1200514424625972248.tmp/Sweep.cpp:28: undefined reference to `Servo::write(int)'
Sweep.cpp.o: In function `setup':
C:\Users\Owner\AppData\Local\Temp\build1200514424625972248.tmp/Sweep.cpp:15: undefined reference to `Servo::attach(int)'
I have managed to compile other code perfectly, so I don't think it's a driver issue........
Here is an example that works:
int servoPin     =  2;    // control pin for servo motor
int minPulse     =  600;  // minimum servo position
int maxPulse     =  2400; // maximum servo position
int turnRate     =  100;  // servo turn rate increment (larger value, faster rate)
int refreshTime  =  20;   // time (ms) between pulses (50Hz)
/** The Arduino will calculate these values for you **/
int centerServo;         // center servo position
int pulseWidth;          // servo pulse width
int moveServo;           // raw user input
long lastPulse   = 0;    // recorded time (ms) of the last pulse
  pinMode(servoPin, OUTPUT);                                       // Set servo pin as an output pin
  centerServo = maxPulse - ((maxPulse - minPulse)/2);
  pulseWidth = centerServo;                                        // Give the servo a starting point (or it floats)
  Serial.println("      Arduino Serial Servo Control");
  Serial.println("Press < or > to move, spacebar to center");
  Serial.println();
        // wait for serial input
  if (Serial.available() > 0) {
        // read the incoming byte:
    moveServo = Serial.read();
        // ASCII '<' is 44, ASCII '>' is 46 (comma and period, really)
    if (moveServo == 44) { pulseWidth = pulseWidth - turnRate; }
    if (moveServo == 46) { pulseWidth = pulseWidth + turnRate; }
    if (moveServo == 32) { pulseWidth = centerServo; }
        // stop servo pulse at min and max
    if (pulseWidth > maxPulse) { pulseWidth = maxPulse; }
    if (pulseWidth < minPulse) { pulseWidth = minPulse; }
        // print pulseWidth back to the Serial Monitor (uncomment to debug)
     Serial.print("Pulse Width: ");
     Serial.print(pulseWidth);
     Serial.println("us");   // microseconds
  // pulse the servo every 20 ms (refreshTime) with current pulseWidth
  // this will hold the servo's position if unchanged, or move it if changed
  if (millis() - lastPulse >= refreshTime) {
    digitalWrite(servoPin, HIGH);   // start the pulse
    delayMicroseconds(pulseWidth);  // pulse width
    digitalWrite(servoPin, LOW);    // stop the pulse
    lastPulse = millis();           // save the time of the last pulse
Please help!  Thanks!
Seattle, WA USA
Seattle, WA USA
But, I'm having some problems with other code that I'm not going to show you...
Well, good luck resolving the issues.
UK
Online Online
It is very unlikely to be a compiler or a driver issue.
It is more likely related to your installation, but like the man said, without seeing your code...
It's the example code under file -> examples -> servo -> sweep.
I apologize for the inconvenience.  I thought it came standard
with all installations of the arduino IDE.  Here it is:
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
help?
Seattle, WA USA
Seattle, WA USA
When I compile that code, the only "error" I get is:
Binary sketch size: 2,666 bytes (of a 30,720 byte maximum)
It looks like you've managed to hose up the Servo library somehow.
UK
Online Online
I hate that example.
How else would you propose I do the same thing?  Coincidentally, the example should do exactly what I need my servo to do....  If you have any suggestions, could you let me know?  Thanks!
UK
The comments look reasonable, but the code doesn't do what the comments say - hardly a good example to set.
Melbourne, Australia
Shannon Member
Lua rocks!
It compiled OK for me under version 1.0 of the IDE.
What version of the IDE do you have? What board is selected? What operating system are you using?
All the code has to do is turn the servo 180 degrees, delay for 15ms or so, and turn back 180 degrees.  How could I do this (more efficiently) ?
UK
Online Online
If you've managed to hose the Servo library, it seems likely to me that you've hosed other libraries too. I'd concentrate on fixing that first, if you intend doing more Arduino projects.
