Topic: Using Solid State Relays with PWM on an Incandescent Bulb - Wiring Help Needed (Read 18667 times) previous topic - next topic
be80be
If the op want's to make one of the dimer's i post here the link to the SCH
http://www.inmojo.com/files/AMIfv956v0gqGQq4kfwh2528TEfTGlskTwl_yXylLv3GSysROxYTsc7JphvdWQo7AnoNdEK3CcHlJcEZN2PMXYG9H4LpjIw_VEETiTOi8xxiNqs-ekluFawYqmqV08UT6R9v7aZ5e9qHn69hOxmTlUpU84b1PBOGPA/ac_dimmer_schematic.pdf
And if you go down to the bottom of the page there the arduino code to run it.
http://www.inmojo.com/store/inmojo-market/item/digital-ac-dimmer-module/
brendanwilding
Out of curiosity, if the PWM frequency was changed to something much lower, say 30Hz, would it then be possible to control the intensity via PWM? I understand its probably not going to be perfectly 'in-sync' but if the fading is fast it shouldn't matter?
You can change the arduino PWM frequency quite easily (http://www.arduino.cc/playground/Code/PwmFrequency), however I have only tried increasing the PWM in the past.
be80be
You could use The PWM but it doesn't work well at all.
It's like this I tried this years ago what happens is some times you'll get a 1/2 off light next time its 3/4  then the next it jumps to off and you can see it like flickering.
Now with zero crossing you can make it soft and slow change without flickering.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
