Topic: Due pinout diagram (Read 363320 times) previous topic - next topic
graynomad
Quote
The addition of quadrature inputs would be a great help.
Quote
primary pin designations and has a empty box so that the user can designate what pens are used for what purpose in their project
Both good ideas and I'll put them on my todo list, but I gotta say I have many other things on that list all with a higher priority (at present).
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
gogol
Also, if you can make a second diagram that listed the primary pin designations and has a empty box so that the user can designate what pens are used for what purpose in their project, it would be very helpful.
Seems that you had a similar need, that I had. I created a diagram for the DigiX, where I combined both needs in one document.
There is an empty transparent form field over the additional information, which can be filled. Once filled, the field chances to solid background and covers the initial information.
Have a look at:
http://digistump.com/board/index.php/topic,1211.0.html
When Graynomad allows, I could overlay his PDF in the same way!
graynomad
That's OK by me as long as the credit blurb stays intact, but I can't see what you mean, all I can find on that link is a JPEG.
______
Rob
gogol
In the very first post of that thread is an PDF linked.
DigiX-Pinout-beta-095a.pdf
graynomad
The only link I can see in that post is this
http://digistump.com/wiki/digix/tutorials/pinout
Maybe I can't see attachments because I'm not a member of that forum.
and
Gets a server not found error, although that might be a temp thing, I'll try again later.
______
Rob
gogol
You need to login, to see the attachment unfortunately.
However I attach it here as well
gogol
Enclosed now the current PDF with overlayed form fields, like I did for the DigiX.
In PDF-reader you need to "highlight existing fields" to see, where those fields are.
Once such a field is filled with own comment, it gets visible and covers the underlying basic information.
promacjoe
Thank you very much, this should help tremendously.
And I'm sure others will appreciate it just as much as I do.
Sam.
graynomad
@gogol
Do you want me to add a link on the first post? With appropriate credit of course.
______
Rob
gogol
@gogol
______
Rob
Of course, feel free to do so!
regards
   Gogol
Nccmayur
MACB  ETH 14 pin connector is shown in schematic
but not seen on BOARD
graynomad
Correct, the schematic is wrong.
Why is is wrong and why not make it right? Who knows.
______
Rob
gogol
Those pins are on the DigiX available. However I miss some more pins:
  • The NRST pin, see:  http://forum.arduino.cc/index.php?topic=160361.0
  • The Erase-Pin, to allow easy programming with an openwrt-based WIFI-to-UART device
  • The Backup-Voltage-Pin
eLabGuy
I don't get it, why they tie C29,A28  and C26,A29 together??  :smiley-eek-blue:
graynomad
Why indeed?
I haven't looked at the functions of those pins for ages, maybe there was a good reason but IIRC I couldn't think of one when I first saw the schematic.
______
Rob
