Topic: Due pinout diagram (Read 375827 times) previous topic - next topic
Armindo
Very good!!! Thanks a lot.
polysysdelta
salaideva
will you please point where is the clock(84 MHz)? :smiley-eek:
graynomad
There is no external 84MHz clock AFAIK, I think you can put a clock signal out a pin but I doubt it would be the full 84MHz, maybe but that would be such an uncommon requirement I don't think it's needed on the diagram.
Also running 84MHz out to those headers would be an exercise in futility I suspect,
If it exists I'm willing to listen to arguments though.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
spicetraders
THX, just received my first DUE, sadly it is not working but will get another to replace.
vaclav
It may have been noted - but...
Is is possible that I2C ports SAM designations port numbers only are reversed?
SCL1 reads  TWCK0
SDA1 reads  TWD0
and the "no number" I2C SAM designators are TWCK1 and TWD1
cdan
Rob Gray, you saved me a great deal of time.
Excellent job, thx.
vaclav
Very minute / minor observation
The "TX" LED ( below USB native port ) is green, not yellow as shown on schematic.
Wurstnase
#159
Apr 26, 2015, 11:23 pm Last Edit: Apr 28, 2015, 07:34 pm by Wurstnase
Great job!
tsester
Thanx a lot for the diagram :)
SicongLiu
Can I use the internal resistors of pin14~19 by pinMode(pin,INPUT_PULLUP)? Does DUE has internal resistor on these pins?
_pepe_
#162
Jul 15, 2015, 03:30 pm Last Edit: Jul 15, 2015, 03:32 pm by _pepe_
Yes, you can activate internal resistors on these pins.
sinq
sinq
MrAl
One of the best diagrams i have seen so far for just about any micro controller.  Very clear and well laid out, easy to see where everything goes and where everything comes from.
Thanks.
