Pages: 1 ... 5 6 [7] 8   Go Down
Author Topic: Due pinout diagram  (Read 52572 times)
I read through this thread and want to thank everyone for making up the pin out for the DUE.  As a newbie on this board, it is very helpful.  I found the pinout at www.robgray.com/temp/Due-pinout-temp.jpg, but this does not include the 36 pin hearder at the end of the board.  Is there another pinout posted somewhere that I am missing?  Or does the pin out need to be updated for this large header?
read post # 1 in this thread.
Online Online
O ti distingui o ti estingui
Quote from: Graynomad
I was inspired by your fantastic work and I have created a version for Arduino Uno. This is the link:
http://arduino.cc/forum/index.php/topic,145531.0.html
Bye, Pighixxx
nr Bundaberg, Australia
Really well done Pighixxx.
______
Rob
i got the original picture but the link for the new one is broken.
i printed the original and found it to be quite useful but do have some suggestions re color use. there are some tags (especially the ones for the SPI connector) that have bad combinations of background and text colors that make it virtually impossible to read when printed. i could make no sense out of the SPI connections and had to sharpie them in on my printed copy. using a color laser at original size scaled to fit an 8.5 x 11 inch page
Wahiawa, Hawaii
Since you have the LEDs between the Prog and Native ports, how about adding the other two LEDs Tx and Rx between the Power jack and Prog port (for the 16U2 communications)?
I'm not answering because I assume that these posts are about the new non-Due diagrams and therefore are addressed to Pighixxx.
Pighixxx can you start an English thread for your diagrams so we know which ones people are referring to?
______
Rob
Wahiawa, Hawaii
I am referring to the Due board.  The Due has two other TX/RX LED between the power jack and the USB Programming port.  These LEDs reflect the 16U2 used for the programming port.
Online Online
Hi Rob,
If you find it useful, i have no problem to open a new English thread.
Hi Rob,
I for one will find it useful, now I'm just hoping that an Mega version also will pop up.. and the rest of the board for that matter, doesnt seem that the folks behind Arduino seem to see this as useful for their customers, but I like these.
Online Online
Hi all,
This is the English thread of Arduino Uno Pinout Diagram
Greenville, IL
Warning Novice on board! 0 to 1 chance of errors!
Hi Rob,
http://arduino.cc/forum/index.php/topic,125908.0.html
Yes I know that one, it was that one that started this thread, I was thinking about something along the lines of this thread and the new uno thread, if you don't see the differences..
Back on topic: With reference to the Native USB TX/RX LEDs ('pins' 73 and 72) - I just discovered that these LEDs use negative logic. That is, they light with digitalWrite(x,LOW) and extinguish with digitalWrite(x,HIGH) (the opposite to the L LED on pin 13 which uses positive logic).
So if it's not too much trouble it might be worth noting on the diagram that the LEDs on 72 and 73 are using negative logic. I was using them for debugging just now, and lost about half an hour wondering why my working code was registering a fault and my non-working code wasn't!  smiley-mr-green
Online Online
...I was thinking about something along the lines of this thread and the new uno thread, if you don't see the differences..
Here the MEGA version  smiley-wink
http://arduino.cc/forum/index.php/topic,146511.0.html
Bye
Pages: 1 ... 5 6 [7] 8   Go Up
