Venezuela
Ground.......ground........always ground
« Reply #45 on: November 14, 2012, 09:54:29 pm » |
Hello Gray, CANRX and CANTX in the board should be reversed. Great, great job man!
nr Bundaberg, Australia
Online
« Reply #46 on: November 14, 2012, 10:41:07 pm » |
Fixed and uploaded. Thanks.
______ Rob
Venezuela
« Reply #47 on: November 14, 2012, 11:03:12 pm » |
Sorry Rob, but you just had only to swap CANTX and CANRX inside the board, as follows:  Sorry again for the misunderstanding.
Online
« Reply #48 on: November 14, 2012, 11:15:47 pm » |
Bugger, I swapped everything else  Will fix. EDIT: Fixed (I hope) ______ Rob
« Last Edit: November 14, 2012, 11:21:39 pm by Graynomad »
« Reply #49 on: November 15, 2012, 12:26:09 am » |
Good work.
Germany
« Reply #50 on: November 15, 2012, 02:02:23 am » |
Good work.
I would more than agree with that. Btw. change the places from PWMH2 and CANTX1 and it looks more corporate
Online
« Reply #51 on: November 15, 2012, 02:37:28 am » |
Thanks guys. change the places from PWMH2 and CANTX1 Will do. ______ Rob
« Reply #52 on: November 15, 2012, 02:50:01 am » |
Hi Rob
thanks for the updates!
As you did correctly the change for PWM10 to point to C.18, the comment should now be updated as follows: "Also connected to A.28".
thank you
Dan
Online
« Reply #53 on: November 15, 2012, 03:34:33 am » |
All recent changes (I think) uploaded.
______ Rob
« Reply #54 on: November 15, 2012, 05:30:09 am » |
Rob, thanks for the corrections. One more thing: port C.29 (PWM10) is high current. Could you also move the comment on the left "Allows serial2 to be used for SPI" above the "SCK1" box. This to make the total picture a bit less wide (as such fits better in a document). Anyway I would like to thank you for a super job done. This is a great diagram to be used for all (hey Arduino guys, please take note  best, -Dan
« Reply #55 on: November 15, 2012, 05:48:46 am » |
Great work so far. I have a suggestion: I printed the diagram out, and there's a problem that in print there's a lack of contrast with the yellow-on-grey port pin labels - they are almost unreadable. Given that (for me anyway) that's the most important column on the diagram could you change the colours for something more high contrast?
On pin 10: As you note this is also connected to port C29. Port C29 is referred to as digital pin 77 in Arduino - that is, if you load the Blink example and change the pin to 77, it will blink an LED connected to pin 10. It might be worth noting that as well.
Also could you add digital 'pins' 72 and 73? These aren't physical pins, but they are connected to the RX and TX LEDs near the native port - changing Blink to use pin 72 or 73 will flash them. Ports are C30 and A21 respectively.
« Last Edit: November 15, 2012, 05:57:40 am by stimmer »
Online
« Reply #56 on: November 15, 2012, 08:01:46 am » |
Thanks Stimmer.
I've changed the colour of the port pins. As it's important this is legible in hard copy can you print it out again and see if that's now the case?
Note that at present I'm limiting the size to 2000px wide, this should print well up to about 8" or even A4 without pixelization. When it's more stable I'll upload larger versions.
I've added the LEDs.
But I'm having trouble with your second point. I can see that D10 and D77 are the same pin, IE C.29 or SS0/PWM10. But I can't see that any LED is connected to this. I don't have a Due so can't check this, which LED blinks?
New version uploaded with the above as I see it so far.
_____ Rob
Germany
« Reply #57 on: November 15, 2012, 08:44:59 am » |
Thanks Stimmer.
_____ Rob
Looks every post better, I would let Pin 4 even look like Pin 10 with the bonded Pin A29, and on TX0 RX0 may for USB programming isn'd obvious enough somethink that make it more clear that they are connectet on the programming port would be better my opinion.
« Reply #58 on: November 15, 2012, 09:59:23 am » |
Thanks very much, it is a lot more readable now.
The ports and pins for the TX/RX leds should be swapped. The LEDs themselves are in the correct order (ON,L,TX,RX) but the ports and pins should be in the order D13,D73,D72 ; B.27,A.21,C.30 ; 68,107,103
About D77, what I meant was if you plugged your own LED (and resistor) into D10 on the board, Blink will flash it when led=10 or led=77. It isn't connected to any LED already on the board.
There are some other pin number oddities in arduino_due_x/variant.cpp, for example digitalWrite(79,HIGH) will set both pins 70 and 71 - I don't think it's helpful to add these to the diagram though.
Online
« Reply #59 on: November 15, 2012, 10:04:58 am » |
@Markus Done and uploaded. TX0 RX0 may for USB programming isn'd obvious Is that what you meant? Stimmer, just saw what you wrote. Will respond shortly. ______ Rob
