Author Topic: New library: The Run Library  (Read 635 times)
Get Bitlash: http://bitlash.net
Many posts here boil down to questions about how to run functions on a schedule.  It's such a common requirement, I built it into Bitlash as the "run" command.
I've just posted a tiny library that lets you do the same thing in C from your Arduino sketch.
The Run library does one thing: it runs functions you specify, each at a specified interval.
Here's a sample sketch that toggles pin 13 every 100ms and pin 12 every 125ms:
#include "run.h"
void toggle13(void) {
digitalWrite(13, !digitalRead(13));
void toggle12(void) {
digitalWrite(12, !digitalRead(12));
void setup(void) {
pinMode(13, OUTPUT);
run(toggle13, 100); // call run() to run toggle13 every 100 ms
pinMode(12, OUTPUT);
run(toggle12, 125); // call run() to run toggle12 every 125 ms
void loop(void) {
runner(); // call runner() to run the function scheduler
The Run library on Github: https://github.com/billroy/run
-br
http://bitlash.net
« Last Edit: November 12, 2012, 08:22:24 pm by billroy » Logged
Netherlands
Thanks for sharing,
Can you explain why you cast m=millis() to signed long in the runner() ?
I assume you do it to make the code overflow proof?
Can you proof it is overflow proof? (I don't want to test for ~25 days to check smiley
Rob Tillaart
