Loading...
Pages: [1]   Go Down
Author Topic: ExtendedDatabaseLibrary in conjunction with the standard Arduino SD library  (Read 99 times)
Offline Offline
Full Member
View Profile
I want to use this library ExtendedDatabaseLibrary in conjunction with the standard Arduino SD library. I explore function like readblock and writeblock in "SD2CARD.cpp" but still i am confuse how to use them.
I really appreciate your suggestions
The read and write handlers which i want to use for SDcard
Code:
// Uncomment the line appropriate for your platform
#define TABLE_SIZE 512 // Arduino 168 or greater
// The number of demo records that should be created.  This should be less
// than (TABLE_SIZE - sizeof(EDB_Header)) / sizeof(LogEvent).  If it is higher,
// operations will return EDB_OUT_OF_RANGE for all records outside the usable range.
#define RECORDS_TO_CREATE 10
// Arbitrary record definition for this table.
// This should be modified to reflect your record needs.
struct LogEvent {
  int id;
  int temperature;
logEvent;
// The read and write handlers which i want to use for SDcard
void writer(unsigned long address, byte data)
  //EEPROM.write(address, data);
byte reader(unsigned long address)
  //return EEPROM.read(address);
// Create an EDB object with the appropriate write and read handlers
EDB db(&writer, &reader);
  Serial.println("Extended Database Library + Arduino Internal EEPROM Demo");
  db.create(0, TABLE_SIZE, sizeof(logEvent));
  Serial.print("Record Count: "); Serial.println(db.count());
  Serial.println("Creating Records...");
  int recno;
  for (recno = 1; recno <= RECORDS_TO_CREATE; recno++)
    logEvent.id = recno;
    logEvent.temperature = recno * 2;
    db.appendRec(EDB_REC logEvent);
  for (recno = 1; recno < RECORDS_TO_CREATE; recno++)
    db.readRec(recno, EDB_REC logEvent);
    Serial.print("ID: "); Serial.println(logEvent.id);
    Serial.print("Temp: "); Serial.println(logEvent.temperature);
« Last Edit: November 12, 2012, 11:31:50 pm by Cybernetician » Logged
From Idea To Invention
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
please do not cross post - the other message is in the right subsection ... - http://arduino.cc/forum/index.php/topic,132151.msg994021.html#msg994021 - (been there)
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Pages: [1]   Go Up
Print
Jump to:
