Topic: How to escape while control structure with implement of switch case (Read 3786 times) previous topic - next topic
mr_hacker90
hi. hello everyone. i have a question here. how do i escape while control structure with implement of switch case. basically. i'm using 3x4 keypad. i want to display in serial monitor number 1 when i press keypad number 1 repeatedly until other number is being pressed. currently i managed to display number 1 until 0 in serial monitor. however, when i pressed the keypad, it just shows in serial monitor the number once only. i want to modify the program so that it will display the number repeatedly until the other number is pressed. here is the programming code. the keypad programming code is referred on the arduino playground. http://arduino.cc/playground/Main/KeypadTutorial and the while control structure is referred on the arduino reference http://arduino.cc/en/Reference/While. the program code i have modify already a little bit. but, seems no going as i planned. if i put the while control structure, the number that i pressed display repeatedly however it not break to other keypad numbers. in the programming code, i have made the change under case '1'. i also provide the screenshot of the serial monitor. managed to display number 1 repeatedly, however, did not break the while loop when the other keypad number is being pressed. your help, i really appreciate. thank you.
Code: [Select]
/*  Keypadtest.pde
*  Demonstrate the simplest use of the  keypad library.
*  The first step is to connect your keypad to the
*  Arduino  using the pin numbers listed below in
*  rowPins[] and colPins[]. If you want to use different
*  pins then  you  can  change  the  numbers below to
*  match your setup.
#include <Keypad.h>
const byte ROWS = 4; // Four rows
const byte COLS = 3; // Three columns
// Define the Keymap
char keys[ROWS][COLS] = {
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'#','0','*'}
// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
byte rowPins[ROWS] = { 0, 2, 9, 10 };
// Connect keypad COL0, COL1 and COL2 to these Arduino pins.
byte colPins[COLS] = { 11, 12, 13 };
// Create the Keypad
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
  // set up SERIAL MONITOR:
  char key = kpd.getKey();
  if(key)  // Check for a valid key.
    switch (key)
      case '1':
        while(key = '1'){
        Serial.println("1");
      case '2':
        Serial.println("2");
      case '3':
        Serial.println("3");
      case '4':
        Serial.println("4");
      case '5':
        Serial.println("5");
      case '6':
        Serial.println("6");
      case '7':
        Serial.println("7");
      case '8':
        Serial.println("8");
      case '9':
        Serial.println("9");
      case '*':
        Serial.println("*");
      case '0':
        Serial.println("0");
      case '#':
        Serial.println("#");
  //while(key = key)
  //Serial.println(key);
CrossRoads
#1
Nov 13, 2012, 08:31 am Last Edit: Nov 13, 2012, 08:34 am by CrossRoads Reason: 1
Clear the vale of key after you use it, and use == for comparisons:
Code: [Select]
     case '1':
       while(key == '1'){
        key = 'z';  // or some invalid character
mr_hacker90
Code: [Select]
if i use invalid character, the number 1 will not display continuously. same goes also if i use valid character like number 2.
Code: [Select]
key = '2';  // or some invalid character
CrossRoads
Ah - in that case, when you get a valid key, save it & do the continuous switching on that.
Something like:
Code: [Select]
  { new_key  = key;}
    switch (new_key)
[code]
and make the }s match up at the end again.
[/code]
mr_hacker90
Something like:
Code: [Select]
  { new_key  = key;}
    switch (new_key)
[code]
[/code]
something like this right? but not working also..
Code: [Select]
  char new_key;
    {new_key  = key;}
    switch (new_key)
      case '1':
        while(key == '1'){    // while key 1 is pressed, it will keep repeatedly display number 1.
        key = 'Z';  // or some invalid character
        break;    // supposed that break the case 1 if other case is being pressed
marco_c
This may work as well
Code: [Select]
  static char oldkey;
  if (!key)  // Check for a valid key.
     key = oldkey;
/* -------- This code not needed if all we want is to print the key
    switch (key)
      case '1':
      case '2':
      case '3':
      case '4':
      case '5':
      case '6':
      case '7':
      case '8':
      case '9':
      case '*':
      case '0':
      case '#':
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
Arduino++ blog https://arduinoplusplus.wordpress.com
mr_hacker90
haha... yeap.. it loop continuously however, did not not display the number respective to the keypad pressed... the serial monitor blank..
Code: [Select]
  static char oldkey;
     key = oldkey;
marco_c
Oops! You need to have an else that saves the key to oldkey if the key is valid. This remembers it for next time.
CrossRoads
Try this.  I don't think you need the while's - if a key press is not received, just switch based on the last key that was received.
Code: [Select]
key = kpd.getKey();
    new_key  = key;
switch (new_key)
      case '1':
} // end switch
} //end loop
mr_hacker90
thank you. but, while i want to compile it, it shows error. mentioned that new_key was not declared. so, i declared the new_key
the programming code is like below. but, it just display once only. not repeatedly until the other key is pressed.
Code: [Select]
  char new_key;
    new_key  = key;
    switch (new_key)
      case '1':
  } // end switch
} //end loop
CrossRoads
That's  because you keep declaring these as new variable every pass thru loop here, which I think sets new_key to 0 every time - you could add a serial.print and confirm.
Code: [Select]
  char new_key;
Move
char key;
char new_key;
into the pre-setup area,
and then just use them like I showed in #8.
holmes4
Going back to the OP's original code
Code: [Select]
   switch (key)
     case '1':
       while(key = '1'){
     case '2':
     case '3':
     case '4':
     case '5':
     case '6':
     case '7':
     case '8':
     case '9':
     case '*':
     case '0':
     case '#':
 //while(key = key)
this
Code: [Select]
   switch (key)
does not check that "key" is valid!. It say if key equals the numeric value of the boolean TRUE enter the "then" part of the if statement!
replace if(key){ with something that performs a range check on the value of key eg
if ((key >'0' AND key<='9') OR key = '#' or key = '*'){
Mark
PaulS
Quote
Actually, it says that if key is not 0 (which is the value of NO_KEY), then, do stuff. Any key will result in the stuff being done.
Not that I like that style, mind you. I prefer explicit tests myself. Except in the case of pointers.
mr_hacker90
Code: [Select]
   switch (key)
Mark
i think the outcome is still the same if i use if control structure. below is the programming code. still yet, display once the number respective to the keypad number. not repeatedly the number respective to the keypad number that being pressed.
Code: [Select]
/*  Keypadtest.pde
*  match your setup.
#include <Keypad.h>
 {'1','2','3'},
 {'4','5','6'},
 {'7','8','9'},
 {'#','0','*'}
 if (key == '1') {
 else if (key == '2') {
 else if (key == '3') {
 else if (key == '4') {
 else if (key == '5') {
 else if (key == '6') {
 else if (key == '7') {
 else if (key == '8') {
 else if (key == '9') {
 else if (key == '*') {
 else if (key == '0') {
 else if (key == '#') {
CrossRoads
Follow the complete library example, save  the key value it is returned when a key is pressed
Code: [Select]
//add this
byte new_key;
void setup(){
// whatever you had
void loop(){
  char key = keypad.getKey();
  if (key != NO_KEY){
    new_key = key;  //new_key is only updated when a key is pressed
//then add your
//switch (new_key),
//or the slower if (key == '1') etc.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
