Loading...
Pages: [1]   Go Down
Author Topic: Arduino and Android - USB loosing packages  (Read 408 times)
Offline Offline
Newbie
View Profile
Hello folks,
I'm trying to interact with my Arduino UNO from my Android tablet running 4.0.3 and got everything working using the Android USB Host API, which means I can send data over USB to the board and read it there via Serial.read() successfully. Now I'm trying to implement a feedback functionality, which means the other way around, sending from the Uno and reading on the tablet. This works also quite well using Serial.write() but I got a little problem: Sometimes, there are no bytes transferred and some other times, only some of them, so the content I'm sending is cut in half. Any suggestions how to fix this? I'm asssuming the Serial port has some issues sending all of the data, perhaps I should change the baud-rate which is currently at 9600?
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
No. Most likely, you are expecting serial data to miraculously arrive all at once.
Post some code, if you really want help.
Logged
Offline Offline
Newbie
View Profile
Thanks. I'm currently using the following code to communicate with the board (written for Android in Java, off course)
Code:
byte[]data = new byte[1024]; //bigger size just to make sure...
int returnLen = conn.bulkTransfer(epIN,data,data.length,500); //epIN is the
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Is that the code for sending data to the Arduino, or for getting data from the Arduino?
Where is the Arduino code?
Logged
Offline Offline
Newbie
View Profile
Arduino simply uses
Code:
Serial.write(5); //sending 5 as an example
Logged
Pages: [1]   Go Up
Print
Jump to:
