Topic: Transmitting SMS from a GSM modem (Read 1 time) previous topic - next topic
lmkaasa
Nov 13, 2012, 02:41 pm Last Edit: Nov 13, 2012, 02:49 pm by AWOL Reason: 1
Hi!
Ive got an project going on bout trying to send an text-message from my arduino to my mobile-phone using an GSM. The program im now using is this:
Code: [Select]
#include <SoftwareSerial.h>
SoftwareSerial cell(2, 3); // RX, TX
char mobilenumber[]="99497322";  // Replace xxxxxxxx with the recipient's mobile number
char textmessage[160]; // used to hold contents of message to send
int b=0;
{  //Initialize serial ports for communication.
cell.begin(9600);
delay(35000); // give the GSM module time to initialise, locate network etc.
// this delay time varies. Use example 26.1 sketch to measure the amount
// of time from board reset to SIND: 4, then add five seconds just in case
pinMode(13, OUTPUT); // use the LED for status
randomSeed(analogRead(0));
void startSMS()
// function to send a text message
digitalWrite(13, HIGH);
cell.println("AT+CMGF=1"); // set SMS mode to text
cell.print("AT+CMGS=");
cell.print("AT+CSCA=+4790002100");
cell.write((byte)34); // ASCII equivalent of "
cell.print(mobilenumber);
cell.write((byte)34);  // ASCII equivalent of " HOME MADE.
delay(500); // give the module some thinking time
void endSMS()
cell.write((byte)26);  // ASCII equivalent of Ctrl-Z
delay(15000); // the SMS module needs time to return to OK status
digitalWrite(13, LOW);
b=random(0, 99);
for (int a=0; a<100; a++)
if (a==b)
startSMS();
cell.print("The random number is: ");
cell.print(b);
endSMS();
do
delay(1);
} while (1>0);
And I got som problem with getting it working, hope that someone maybe would be able to help me ;)
Moderator edit: CODE TAGS
AWOL
Quote
...and?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
HazardsMind
does the mobile number need to have 9+ 949-7322, or does it need area code 9+(XXX) 949-7322 ?
your original number: 99497322
What problems are you getting?
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
