Loading...
Pages: [1] 2   Go Down
Author Topic: SMD crystals for Arduino?  (Read 316 times)
South UK
Offline Offline
Sr. Member
View Profile
Hi all, I'm making another homebrew Arduino board. I want to use a SMD xtall this time.
I have found some of these that look promising http://uk.farnell.com/txc/7a-16-000maaj-t/xtal-16-000mhz-18pf-smd-5-0x3-2/dp/1841946RL
What is the load capacitance on the standard Arduino crystal? This states 18pf so will I still have to use the same 22pf caps as a load?
Thanks
Logged
Canada
Offline Offline
Sr. Member
Sometimes teaching, always learning,
View Profile
I've always used 22pF. I don't think the exact value is important, anything from 18-22pF is acceptable. I have read of people not using caps at all  smiley-roll
Here's that thread: http://arduino.cc/forum/index.php?topic=130003.0
« Last Edit: November 13, 2012, 09:23:10 am by John_S » Logged
Offline Offline
Full Member
Knowledge is proportional to the number of parts destroyed.
View Profile
The capacitance of your traces and the board material will likely exceed the 4pF of difference. You'll be fine with 22 pF.
But you should still include the caps. Your oscillator will start more reliably and be more stable. Without the caps, you're depending on the trace capacitance of the board and other effects like humidity, dirt and oil on the board, etc. which may change with time.
Logged
Offline Offline
Edison Member
View Profile
Older crystals tend to specify higher load capacitance and newer crystals are generally in the 6pf - 12pf range.
Unless you require super accurate timing, pay no attention to the load capacitance specification - most high speed crystals (4Mhz or over) will run without those capacitors.
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
Unless you need better than 0.5% frequency accuracy, you can use a 3-terminal ceramic resonator instead, such as http://uk.farnell.com/abracon/awscr-16-00mtd-t/ceramic-resonator-16mhz-smd/dp/2101362?in_merch=New%20Products. These have the caps built in.
If you do use a crystal, the 2 caps are in series as seen by the resonator. So 2x22pf gives 11pF, and when you add the stray capacitance and mcu pin capacitance you will have close to 18pF.
Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
Grand Blanc, MI, USA
Offline Offline
Faraday Member
"We're a proud service of the Lost Electricity Reclamation Agency"
View Profile
WWW
Always aim to provide the load capacitance specified on the crystal's datasheet.  I use the formula on page 2 here, which is pretty standard.
Turning the formula around, and assuming the two load capacitors are equal gives:
C = 2(CL - CS)
Where C is the load capacitor value, CL is the load capacitance specified in the crystal's datasheet, and CS is stray capacitance.
When I do the maths, assuming CL of 18pF and CS of 5pF, I get 26pF, so I use 27pF (standard value) caps with 18pF crystals.
Many crystals will run without load capacitors, and that might be OK on a breadboard in a pinch, but anything else is just Bad Design. When something isn't working, I don't know why I'd want to have to worry about whether the oscillator is running correctly. I can create more than enough of my own problems in other areas, so I figure I might as well get the oscillator right and not have to add that to the list of possible causes smiley-grin
Logged
Get the infamous "One Million Ohms" board at tINDIE.com: http://tinyurl.com/BuyMohms
South UK
Offline Offline
Sr. Member
View Profile
Thanks for all the useful info guys!
The resonators sound like a good option, I don't need a great level of accuracy, and I'm using a RTC for the longer term time management anyhow smiley
Thanks for the info Jack! It's one thing answering a question for someone but telling them how to answer it themselves is great smiley one thing I'm not sure about is how you calculate the 'stray resistance'?
Thanks again
Logged
Offline Offline
Edison Member
View Profile
Quote
Let me flip that coin for you. If you are OK with the (in)accuracy of a resonator, you are going to be more than OK with the (in)accuracy caused by no load capacitance or out-of-spec load capacitance. A crystal without no capacitance will beat out a resonator and provides you the option to obtain accurate timing in the future if you decide to solder in the capacitor(s).
With that, it is very difficult, in my view, to justify a resonator over a crystal, and that's why you rarely see them used in well designed products.
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
Quote
There is nothing intrinsically wrong with a the design that uses a resonator, if the frequency tolerance and drift of the resonator are within the required parameters. You might just as well say that well-designed products don't use 1% tolerance resistors, because 0.1% tolerance resistors are available.
On the other hand, a circuit using an atmega328p and crystal with no capacitors is definitely not well-designed, because it's running the mcu outside its recommended operating conditions (C1, C2 = 12 to 22pF, see sections 9.3 - 9.4 of the datasheet).
Logged
Offline Offline
Faraday Member
View Profile
WWW
Thanks for the info Jack! It's one thing answering a question for someone but telling them how to answer it themselves is great smiley one thing I'm not sure about is how you calculate the 'stray resistance capacitance'?
Sure thing! As for stray capacitance, that might take some doing to actually measure, and test equipment that I don't have, so I don't calculate it, I just assume 5pF. Note that the Fox document says
Quote
As a rule of thumb, Cstray may be assumed to equal 5.0 pF.
so I just go with that in absence of any better estimate.
For most purposes, resonators are fine too, as noted. The Uno actually uses a resonator I believe.
« Last Edit: November 13, 2012, 02:27:01 pm by Jack Christensen » Logged
Offline Offline
Edison Member
View Profile
There is also the pin capacitance.
Logged
Offline Offline
Faraday Member
View Profile
WWW
Indeed. But in the datasheet (ATmega328 et al), I can only find pin capacitance listed for the low-frequency oscillator.
Logged
Offline Offline
Edison Member
View Profile
I use 7pf as an estimate.
Logged
Offline Offline
Faraday Member
View Profile
WWW
Then add something on top of that for stray capacitance, or would 7pF be pin + stray?
Logged
Offline Offline
Edison Member
View Profile
For pin alone.
Those guys didn't just pick 6pf/12pf load capacitance for no reason.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
