Loading...
Pages: [1]   Go Down
Author Topic: Analog 1.1 VDC A/D reference does not compute?  (Read 496 times)
0
Offline Offline
Sr. Member
Progress is made by lazy people-H Ford/R Heinlein
View Profile
Using the internal analog 1.1 VDC A/D reference does not compute?
I am using a temperature sensor LM34DZ as an input to an Arduino analog input.
The "default" internal voltage ref of ~ 5 vdc is being used.
The LM34DZ outputs a voltage equal to 10mv/deg F.
The analog voltage input reads 0.7952 volts @ 10mv/F = 79.52F
The analog count is 159 out of 1024 steps or 0-1023 (10 bit A/D)
159/1023 = .155425219941 X 5000 (mv) = 777.126099705 / 10 mv/F = 77.71 F
This calculation both on the front end voltage and the A/D count is close.
Notes: The exact voltage ref (default) is not exactly 5 VDC but a number close to 5 VDC eg 5.06982.
This gives the calculation 78.77F. vs 79.52F using a 50,000 count voltmeter.
This default ref voltage varies between chip to chip.
The accuracy of the "cheaper" LM34DZ is +-2F
I decided to use the internal A/D 1.1 VDC Voltage ref by using the new command
analogReference(INTERNAL);
The AREF on pin 21 changed from 5VDC to ~ 1.0729 VDC.
The count changed from 159 to 252 with the same input voltage from the LM34DZ.
What does this count of 252 represent?
Note: I am using rev 14 and my various chips are 168P/328P with approximately the same results.
Note: The AREF is not connected to any external voltage source.
 :o :o :o
Logged
"Never trust an Internet bully who insults and makes fun of your level of intelligence."
0
Offline Offline
Faraday Member
ruggedcircuits.com
View Profile
WWW
That....makes no sense. I would have expected a count closer to 720.
Did you take multiple readings? Any chance you're only reading one of the A/D registers (ADCH / ADCL) instead of both?
Logged
0
Offline Offline
Sr. Member
View Profile
I am "eating crow" on this one.
My variable is a byte and I needed to change it to an int when
changing to the 1.1 VDC internal ref.
count 778/1023 * 1100 / 10 works out to my new ambient temp.
Logged
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
Ciao,
if you are hanging the analog reference from standard to internal in the sketch take into account that a analog read + a delay are needed before internal reference is operational.
Here a portion of code that works for me
        // Temperature sensor LM35DZ - Change of analog reference voltage
        // Put to INTERNAL: 1.1 V
        // One analog read + delay are needed to make change operational
        analogReference(INTERNAL) ;
        analogRead(5) ;  // 5 = analog pin 5
        delay(100);
        analog_val_temp = analogRead(5) ; // 5 = analog pin 5
        // Return to DEFAULT analog reference voltage (5V)
        analogReference(DEFAULT) ;
Have a nice day.
Marco.
Logged
Pages: [1]   Go Up
Print
Jump to:
