Loading...
Pages: 1 [2]   Go Down
Author Topic: Noise in ground by Reley  (Read 894 times)
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
With this the problems seems to minimize but it stills affect the LCD randomly.
So add more capacitors and larger electrolytics as well in parallel 100uF.
Yes get a grip of your wiring. Ditch the solderless bread board. Solder it up on prototype board and keep the wiring neat. As mentioned before keep the AC stuff away from the low voltage stuff.
Logged
Offline Offline
Newbie
View Profile
Finally I solve the problem, I tried all your recommendations and finally I nailed it. THANKS TO ALL FOR YOUR HELP!
Well so first of all, I remake my whole circuit, making it cleaner.
Old-circuit Photo
New-circuit Photo
I know, I know, it's still messy but I did my best. For my luck the problem still there in the LCD.  So I followed dc42 advice and connect my LCD directly to my arduino, and it didnt work either, but with the snubber parallel to the load and the LCD connected directly to my arduino the impossible became possible  smiley-grin, now it´s working and the display works great.
So this is my snubber (Resistor 100 ohms 1W, Polyester capacitor 250V .1uF:
In my local store the ceramic capacitors are only of 50V so I tried with a polyester one (250V .1uF) and a resistor of 100 ohms, 1 Watt because of 1/4 watt it burned.
So my solution was adding the snubber in parallel to the Water pump and connecting the LCD directly to the pins of the arduino 5V and GND.
Thanks again for all your help. smiley-lol
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
