Loading...
Pages: [1]   Go Down
Author Topic: serial comunication  (Read 189 times)
indonesia
Offline Offline
Newbie
View Profile
Hi guys,...
Would u help me?
I looking for a way to make my arduino-uno can received many variables from PC. smiley-cool
Exactly I have a project that requires sending data (variables) from Delphi output to arduino, and process it on arduino. smiley-roll-sweat
probably 10 variables.
Please help me.......
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
And how are these variables formatted?
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
indonesia
Offline Offline
Newbie
View Profile
it's all  parameters..
example
VS 2000
its mean VS(Viscosity standard) have a value 2000 smiley-twist
Logged
California
Offline Offline
Edison Member
View Profile
What do you have so far?
Logged
indonesia
Offline Offline
Newbie
View Profile
i'm sorry... So far i try to use gobetwino, but i confused with the syntax. and its really complicated for me smiley-roll-sweat
Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
Have you worked through any of the supplied examples?
Logged
Queens, New York
Offline Offline
Edison Member
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
View Profile
Arduino does not have a split function like Processing does, SO, you need to make your own split function.
Here is something I made to help me. this will take in 3 values and change them to ints.
Code:
#include<string.h>
int X,Y,State,currentCommand=0;
String x,y,state;
// LED connected to pin 13 (on-board LED)
byte ledpin = 13;
  pinMode(ledpin, OUTPUT);
  Serial.begin(9600);       // start serial communication at 9600bps
  if( Serial.available())       // if data is available to read
    digitalWrite(ledpin, HIGH); //if data is being entered
    char val= Serial.read();
    if (val == ','){
      currentCommand++;
    else {
      switch (currentCommand) { //add more case statements for more data
      case 0:
        x += val; //stores as a string
        val = ' '; //clear for new char
      case 1:
        y += val; //stores as a string
        val = ' ';
      case 2:    //gets the last data
        state += val; //stores as a string
        val = ' ';
        currentCommand = 0; // this only allows one char to be saved here, modify to save more.
        X=x.toInt();               //delete .toInt() if needed
        Y=y.toInt();               //delete .toInt() if needed
        State = state.toInt(); //delete .toInt() if needed
        //shows what you entered
        Serial.print(X);
        Serial.print(", ");
        Serial.print(Y);
        Serial.print(", ");
        Serial.println(State);
        x="";y="";state=""; //clear values
        X=0;Y=0;State=0; //clear values
  digitalWrite(ledpin, LOW);
Hope this is able to get you started.
Moderator edit: CODE TAGS dammit.
« Last Edit: November 13, 2012, 12:40:39 pm by AWOL » Logged
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
indonesia
Offline Offline
Newbie
View Profile
Yes... But
it doesnt work correctly. And i can't trace the error because i confused with the sintax.
maybe someone can help me with the other ways?
Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
Quote
First mention of an error.
Care to expand?
Logged
indonesia
Offline Offline
Newbie
View Profile
thanks a lot HazardsMind smiley-kitty smiley-kitty....
It really helps me:)
Logged
Offline Offline
Jr. Member
View Profile
Yes... But it doesnt work correctly. And i can't trace the error because i confused with the sintax.
Maybe you can tell us (1) what you're doing already (i.e., show us your code), (2) what you expect it to do, (3) what it's actually doing, and (4) what errors you're getting?
Logged
Pages: [1]   Go Up
Print
Jump to:
