Author Topic: serial comunication  (Read 190 times)
indonesia
Hi guys,...
Would u help me?
I looking for a way to make my arduino-uno can received many variables from PC. smiley-cool
Exactly I have a project that requires sending data (variables) from Delphi output to arduino, and process it on arduino. smiley-roll-sweat
probably 10 variables.
Please help me.......
UK
And how are these variables formatted?
indonesia
it's all  parameters..
example
VS 2000
its mean VS(Viscosity standard) have a value 2000 smiley-twist
California
Online Online
What do you have so far?
indonesia
i'm sorry... So far i try to use gobetwino, but i confused with the syntax. and its really complicated for me smiley-roll-sweat
UK
Have you worked through any of the supplied examples?
Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
Arduino does not have a split function like Processing does, SO, you need to make your own split function.
Here is something I made to help me. this will take in 3 values and change them to ints.
#include<string.h>
int X,Y,State,currentCommand=0;
String x,y,state;
// LED connected to pin 13 (on-board LED)
byte ledpin = 13;
  pinMode(ledpin, OUTPUT);
  Serial.begin(9600);       // start serial communication at 9600bps
  if( Serial.available())       // if data is available to read
    digitalWrite(ledpin, HIGH); //if data is being entered
    char val= Serial.read();
    if (val == ','){
      currentCommand++;
    else {
      switch (currentCommand) { //add more case statements for more data
      case 0:
        x += val; //stores as a string
        val = ' '; //clear for new char
        break;
      case 1:
        y += val; //stores as a string
        val = ' ';
        break;
      case 2:    //gets the last data
        state += val; //stores as a string
        val = ' ';
        currentCommand = 0; // this only allows one char to be saved here, modify to save more.
        X=x.toInt();               //delete .toInt() if needed
        Y=y.toInt();               //delete .toInt() if needed
        State = state.toInt(); //delete .toInt() if needed
        //shows what you entered
        Serial.print(X);
        Serial.print(", ");
        Serial.print(Y);
        Serial.print(", ");
        Serial.println(State);
        x="";y="";state=""; //clear values
        X=0;Y=0;State=0; //clear values
        break;
  digitalWrite(ledpin, LOW);
Hope this is able to get you started.
Moderator edit: CODE TAGS dammit.
« Last Edit: November 13, 2012, 12:40:39 pm by AWOL » Logged
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
indonesia
Yes... But
it doesnt work correctly. And i can't trace the error because i confused with the sintax.
maybe someone can help me with the other ways?
UK
First mention of an error.
Care to expand?
indonesia
thanks a lot HazardsMind smiley-kitty smiley-kitty....
It really helps me:)
Yes... But it doesnt work correctly. And i can't trace the error because i confused with the sintax.
Maybe you can tell us (1) what you're doing already (i.e., show us your code), (2) what you expect it to do, (3) what it's actually doing, and (4) what errors you're getting?
