Topic: DPWS (Device Profile for Web Services) (Read 957 times) previous topic - next topic
yurilobao
Hello all!
I'm new to the forum and would like to take a question about the Arduino Uno.
I am wanting to implement a project using the DPWS (http://www.ws4d.org/ or http://www.soa4d.org/) and would like to know if the arduino supports such technology?
The DPWS is implemented in JAVA as well in C. I can compile directly to the arduino or should I use the standard language of arduino?
Thank you!
Yuri Lobão Tourinho
Mestrando em Mecatrônica (PPGM-UFBA)
Bacharel em Ciência da Computação (PUC-GO)
Certificação: SCJA 1.0
Blog: http://yuri
MikMo
What are the memory requirements of these DPWS ?
Arduino boards have extreamly limited memory, and no way to run Java.
PeterH
Arduino can host web services and this is the sort of framework that could be used to create and access those web services, but the question is whether the framework would run on the limited resources available in an Arduino. If it can, I don't see any reason why you couldn't use it within an Arduino.
I only provide help via the forum - please do not contact me for private consultancy.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
