Topic: Connect Gate Remote Board Directly to Arduino...? (Read 3792 times) previous topic - next topic
JsChiSurf
#15
Nov 16, 2012, 03:42 pm Last Edit: Nov 16, 2012, 03:54 pm by JsChiSurf Reason: 1
Perfect.  Thanks for the reply.  If I have any troubles, in the words of Arnold, I'll be back...  :smiley-yell:
Stupid question.  Are the pins on the opto-isolator marked so you know which is which?
terryking228
Look in the PDF that is linked on the ArduinoInfo.info WIKI.  Pin 1 is marked.
Pin numbers go Counter-Clockwise from pin 1. As seen from the TOP.
This is because people are used to going clockwise with pin numbers.  On vacuum tubes. From the BOTTOM of the socket. Inside the chassis where you are soldering the filament transformer wires etc etc.  In 1949. Everybody knows that   8)
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
JsChiSurf
Thanks, I saw that in the PDF, but didn't know where to go from there.
Everybody but me  :smiley-mr-green:
be80be
What I don't under stand is why you changed from transistor to Logic Output Optoisolators
If you think it works better you can still hook it up backward and 2 I showed you clearly how this worked with a transistor.
JsChiSurf
Actually, I'll probably try it both ways just to learn.  I like the simplicity of the opt-isolator though, as it appears I don't have to worry but any other ground connections, etc.  It just seems simpler to me.  Certainly appreciate your help as well.  I already have 2 NPN transistors (1 for backup, lol), so they will probably get first shot.
JsChiSurf
#20
Nov 17, 2012, 08:56 pm Last Edit: Nov 17, 2012, 09:05 pm by JsChiSurf Reason: 1
So, I decided to breadboard out my setup for testing, by seeing if I could toggle the remote board via momentary button connected to the Arduino and breadboard, and have the state of that button change the I/O on the Arduino to High for the pin I connected the NPN base to, whose collector and emitter are connected to the remote board HIGH and LOW in the location where the remote's momentary button is connected (see below):
And, I'm proud to say, it works like a charm!  Yes!  Ignore my solder job, I'm still trying to perfect it.
Gonna try optos next, just for fun, but I'm ready to package this up and integrate it with the rest of my setup, and into my Android app now.
Thanks for those who helped assist / clarify my understanding.
