Loading...
Pages: 1 2 3 [4] 5   Go Down
Author Topic: Read a freqency from an analog pin  (Read 1015 times)
UK
Offline Offline
Edison Member
What a host of balls she had seen: gaity, the brass buttons...
View Profile
WWW
Values are fictive. I want to separe 2 frequences. (frequences from microphone)  smiley-eek
If you can't be bothered to answer our simple questions, then I can't be bothered to help you.
I have asked for simple, straight forward, information, which you have repeatedly failed to give us.
Unless you do so there is NOTHING we can do for you!
Logged
Offline Offline
Newbie
View Profile
OK. So, i have a microphone connected to analog 0. When i speak, the microphone get a frequence.If this frequence is bigger than a "constant value", a led is on. If frequence is less than a " constant value" , another led is on. That is all.
"constant value"= a frequence, wich i write in the code.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Frequency and volume are two completely different things. Is frequency really what you want?
HOW IS THE DAMNED MICROPHONE CONNECTED?
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
I asked quite a long time ago what amplification do you have between the microphone and the analog pin.
If the answer is "none", then we are all really just wasting our time, and I will lock the thread.
Start answering questions.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
View Profile
I have transistor for amp.
Logged
Offline Offline
Edison Member
View Profile
Rather than attempting a project that is way beyond your skill levels, try to break the project into doable pieces and do them one at a time, starting with the simpler ones (like turn on / off an led).
In your case, those would be something for you to think of:
1) write code to turn on / off an led;
2) write code to turn on / off an led depending on a value comparison
3) write code to measure frequency;
4) design hardware to process the microphone signal so it can be measured by your arduino.
5) put them all together.
You have to start somewhere and it is best that you start where you can draw upon your skills.
Logged
Offline Offline
Newbie
View Profile
I know how to turn on/ off a led. I don't know how to use frequency reading.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Then you should know how to use Serial.print() to print some data. You should know how to write code properly. You should know how to post that code. You should know how to post the output from your application. You should have at least the vaguest clue about debugging.
Logged
UK
Offline Offline
Edison Member
View Profile
WWW
Trying to infer what you want from your unintelligible ramblings, I think what you want is:
1. Attach a microphone to the Arduino.
You will require an amplifier to boost the signal to a level the Arduino can sense.  You should look in to op-amp microphone pre-amplifiers.  There are plenty of resources on the web for them.
2. Find the frequency of the signal.
There will be many many frequencies present in the signal, not just one.  You will need to sample a clip of audio from the microphone and do a Fast Fourier Transform on it.  This will give you a list of frequencies present in the signal and their amplitudes.
3. Light an LED depending on the frequency.
You can use the list of frequencies provided by the FFT to find the frequency that has the greatest amplitude.  This is the peak frequency, and can be used to make decisions, like is it above or below a threshold?  Is there no clear peak frequency?  Etc.
So, you have some reading to go and do:
1. Read up on attaching a microphone to an Arduino using a pre-amp circuit.
2. Read up on Fast Fourier Transforms, and find some Arduino code to do it (hint, look for fix_fft).
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
and
3) Have a clear sense of scale. Measuring a 1Hz signal with a microphone is unrealistic, as is measuring a 1MHz signal.
Quote
I will employ my psychic powers to endeavour to draw your schematic.
Or, you could save me the considerable mental effort and post it.
« Last Edit: November 15, 2012, 09:21:29 am by AWOL » Logged
Offline Offline
Full Member
View Profile
Here a nice link to give a understanding of sound and they have a nice link to a real good preamp
http://courses.oliviarobinson.com/wt/node/79
Never could figure wHy we need a crystal ball now I NO
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Did you get one when you joined the forum? I'm still waiting on mind. The psychic keeps saying "any day now".
Logged
Offline Offline
Newbie
View Profile
Now it works!  smiley
Thank you for answers! You are the best!  smiley
Logged
UK
Offline Offline
Edison Member
View Profile
WWW
If he's learned all that so fast, he's either a genius (which somehow I doubt), or what he is trying to do is completely different to what he is saying he is trying to do.
Logged
Offline Offline
Full Member
View Profile
Na some one here used a magic wand with there crystal ball
Logged
Pages: 1 2 3 [4] 5   Go Up
Print
Jump to:
