Pages: 1 [2] 3 4 5   Go Down
Author Topic: Read a freqency from an analog pin  (Read 989 times)
[quite] I want only a line , wich read frequency...[/quote]
Try this:
  freq=freq_read(pin); //read frequency on pin
You are welcome.
Seattle, WA USA
Seattle, WA USA
1.long getFrequency(int pin) {
2.#define SAMPLES 4096
3.long freq = 0;
4.for(unsigned int j=0; j<SAMPLES; j++) freq+= 500000/pulseIn(pin, HIGH, 250000);
5.return freq / SAMPLES;
6.}
Is right there on the page you linked to. Surely you can figure out how to call this function.
Boston area, metrowest
Isn't this simple enough?
long freq = 0;
Thanks for answers.  smiley
I write the code below:
#include <FreqCounter.h>
double frequency;
  pinMode(5,OUTPUT);
  pinMode(11,OUTPUT);
  pinMode(12,OUTPUT);
  pinMode(15,OUTPUT);
  pinMode(16,OUTPUT);
  pinMode(17,OUTPUT);
long getFrequency(A0); {
long freq = 0;
for(unsigned int j=0; j<SAMPLES; j++) freq+= 500000/pulseIn(A0, HIGH, 250000);
frequency = freq/SAMPLES;
if (frequency <1) { digitalWrite(5, HIGH);
                   digitalWrite(11,HIGH);}
if (frequency >=1) { digitalWrite(12, HIGH);
                   digitalWrite(15,HIGH);}
No errors, but circuit doesen't work. I have mistakes in the code?
UK
What a host of balls she had seen: gaity, the brass buttons...
So how do those LEDs ever turn off then?  You are turning them on, but never off.
UK
The only case where "frequency" is less than one is when it is zero.
Seattle, WA USA
Seattle, WA USA
     long freq = 0;
     if (frequency <1)
     if (frequency >=1)
Without your atrocious indenting, and with curly braces every where, this is your loop function. So, what exactly is the function prototype in the loop() function for? You don't call the function anywhere, nor do you implement it, so get rid of it. Then, the { and } that follow it are useless.
You really don't understand what frequency means, do you?
Now ,it is correct?
double frequency;
  pinMode(5,OUTPUT);
  pinMode(11,OUTPUT);
  pinMode(12,OUTPUT);
  pinMode(15,OUTPUT);
  pinMode(16,OUTPUT);
  pinMode(17,OUTPUT);
     long freq = 0;
     if (frequency <5000)
     if (frequency >5000)
UK
What about turning the LEDs off?
What if the average is 5000?
Now ,it is correct?
You're the one with the hardware, you tell us.
« Last Edit: November 14, 2012, 01:20:35 pm by AWOL » Logged
Left Coast, CA (USA)
Measurement changes behavior
This is a very strange posting thread, maybe well on it's way of becoming a classic.  smiley-wink
Lefty
UK
Now ,it is correct?
double frequency;
  pinMode(5,OUTPUT);
  pinMode(11,OUTPUT);
  pinMode(12,OUTPUT);
  pinMode(15,OUTPUT);
  pinMode(16,OUTPUT);
  pinMode(17,OUTPUT);
     long freq = 0;
Did you actually make any changes...?
For your reference:
Quote from: Wikipedia
Frequency is the number of occurrences of a repeating event per unit time. It is also referred to as temporal frequency. The period is the duration of one cycle in a repeating event, so the period is the reciprocal of the frequency. For example, if a newborn baby's heart beats at a frequency of 120 times a minute, its period (the interval between beats) is half a second.
... and ...
In mathematics, a multiplicative inverse or reciprocal for a number x, denoted by 1/x or x−1, is a number which when multiplied by x yields the multiplicative identity, 1. The multiplicative inverse of a fraction a/b is b/a. For the multiplicative inverse of a real number, divide 1 by the number. For example, the reciprocal of 5 is one fifth (1/5 or 0.2), and the reciprocal of 0.25 is 1 divided by 0.25, or 4. The reciprocal function, the function f(x) that maps x to 1/x, is one of the simplest examples of a function which is self-inverse.
« Last Edit: November 14, 2012, 01:30:35 pm by majenko » Logged
UK
Oops, missed the superfluous function prototype.  smiley-kiss
I am very new at programming.   I want to understand what is wrong, but i can't. smiley-cry
That's the only mistake? As I turned off the LED-s? The circuit does not light at all, I put any frequency. Should not light up LEDs?  smiley-cry
ps: sorry for bad english.
UK
There is one more mistake.  The program is wrong.  Just plain wrong.  First steps is to read up on the basic syntax of C so that you can at least have a clue what you're doing.
Then, you need to properly define what it is you want to achieve.
From that you can break it down into a number of actual steps to achieve your goal.
You can then convert those steps into C code in the form of a program.
This is called Top Down Programming.
Top-down approaches emphasize planning and a complete understanding of the system. It is inherent that no coding can begin until a sufficient level of detail has been reached in the design of at least some part of the system.
« Last Edit: November 14, 2012, 01:43:21 pm by majenko » Logged
Can make for me a correct program with this library?
Pages: 1 [2] 3 4 5   Go Up
