Topic: MOTOR FOR HEAVY LOAD (Read 781 times) previous topic - next topic
isakiwanuka
WHAT MOTOR CAN I USE FOR A 25KG LOAD AND IT IS GEARED ...........
isakiwanuka
i am planning to use arduino mega
and need position control
AWOL
You need to provide more detail.
Are you lifting the object?
Rotating it?
In which axis?
How fast?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
isakiwanuka
sorry
i am rotating a satellite dish and the other is for moving the dish up and down ....... satellite weights 25 kg ..... mostly need position control and want to use gear motors and not a stepper motor
so need a mototr that can handle a heavy load and rotate 36o degrees cw and ccw ....
zoomkat
If the dish mount is properly designed and balanced, a large motor may not be necessary. A $10 cordless screwdriver motor might do the rotatrion job. For up/down operaton, linear acruators like below are normally used.
https://www.google.com/search?q=satellite+dish+actuator&num=100&hl=en&lr=&tbo=u&as_qdr=all&tbm=isch&source=univ&sa=X&ei=AdOjUNrFB4qx0AGtkYCICw&ved=0CGEQsAQ&biw=1196&bih=641
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
